Calculate Pressure in Hydraulic Cylinder
To calculate the pressure in a hydraulic cylinder with a 375 kg load and a 95 mm piston diameter, the correct force should be calculated using F = m x g, resulting in 3,444.75 N. The area of the piston is determined using the formula A = π(d^2)/4, yielding approximately 0.0071 m². The pressure is then calculated using P = F/A, which gives a result of about 484.5 kPa. It's important to ensure that the correct mass is used in calculations and to account for any additional forces acting on the piston. Accurate calculations are crucial for understanding hydraulic systems.
jezman
hey everyone, can someone please help me out with this one, I am a bit stuck with this
using the law F = PXA and F = mxa
calculate the pressure in a hydraulic cylinder, when the load of 375kg, is applied to the piston
piston diameter it 95mm
so far what i have worked out is as follows
force on the piston is:
F = M x 9.81
= 250x9.81 = 2452.5N
now for the area
pi x rxr
= 3.1416 x 37.5x37.5
=4417.86 mm2
now if I am correct i need to change the mm2 to m2?
so...
4417.86mm2 /1,000,000
=0.00441786m2
therefore...
f=2452.5N
A=0.00441786m2
P = F/A ?
555,133.028p
or 555.133kp
is this correct guys or am i way out?
if anyone could help me out with this it would be greatly appreciated
thansk
You might want to check the value that you used for the radius of the cylinder.
Other than that your method looks fine.
If the load is 375 kg, why did you use 250 kg in your calculations?
Good catch SteamKing. I missed that second error!
Actually , all your work is messed up , the pressure inside the cylinder would be the summation of the external force and the weight of the piston divided by the area of the piston..
So:
P= ( Fex + W ) / A
A= 3.14 * d^2 / 4 = 3.14 * (0.095)^2 / 4 = 0.0071 m^2
Fex = 375 * 9.81 = 3.44 k N
..and since you didn't mention the mass of the piston I'll assume its negligible
so now:
P = 3.44 / 0.0071 = 484.5 kPa
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
