Help understanding a SR equation
  • Thread starter Thread starter Reikoku
    Sr
Reikoku
Hi all, I'm currently a stage 1 Physics student at uni; and in the process of learning Special Relativity.
I was reading my textbook and came across this in the Time and Space section:
Suppose an observer in frame S measures two flashbulbs going off at the same time t but at different x-coordinates x1 and x2. Then an observer in frame S` would measure the time interval t`1 - t`2 between the flashbulbs going to be:
t`1 - t`2 = \gamma((x2-x1)*(u/c)^2)
I was wondering why it's t`1 - t`2 instead of the usual t`2 - t`1. I assume it's to prevent the final answer being negative? I feel like I'm being stupid asking this :|
It's just to get rid of a minus sign. The full transformation is:
\Delta t' = \gamma(\Delta t - v\Delta x/c^2)
Since Δt = 0, you get:
\Delta t' = -\gamma(v\Delta x/c^2)
Where Δt' is the usual t'2 - t'1. But if you switch the order you can get rid of the minus sign on the right hand side.
Yeah that makes sense now, cheers! :D
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
Thread 'Dirac's integral for the energy-momentum of the gravitational field'
See Dirac's brief treatment of the energy-momentum pseudo-tensor in the attached picture. Dirac is presumably integrating eq. (31.2) over the 4D "hypercylinder" defined by ##T_1 \le x^0 \le T_2## and ##\mathbf{|x|} \le R##, where ##R## is sufficiently large to include all the matter-energy fields in the system. Then \begin{align} 0 &= \int_V \left[ ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g}\, \right]_{,\nu} d^4 x = \int_{\partial V} ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g} \, dS_\nu \nonumber\\ &= \left(...
Abstract The gravitational-wave signal GW250114 was observed by the two LIGO detectors with a network matched-filter signal-to-noise ratio of 80. The signal was emitted by the coalescence of two black holes with near-equal masses ## m_1=33.6_{-0.8}^{+1.2} M_{⊙} ## and ## m_2=32.2_{-1. 3}^{+0.8} M_{⊙}##, and small spins ##\chi_{1,2}\leq 0.26 ## (90% credibility) and negligible eccentricity ##e⁢\leq 0.03.## Postmerger data excluding the peak region are consistent with the dominant quadrupolar...
