Help with finding vintage valve amplifier circuits (amplifiers for a rock band)
In summary: If you're looking for something that will take you through all the electronics required for guitar players (power supplies, pickups, amps, effects) I can't recommend "Electronics for Guitarists" enough but Denton Dailey enough. It strikes that balance where it is accurate and useful, but doesn't read like an engineering text (and you don't need a degree in Electrical Engineering to understand it). It starts from the beginning and goes from there.This book is great for someone with a little experience in electronics. It is very comprehensive and covers a wide range of topics, from power supplies to guitar effects.
wolram
Dearly Missed
4,446
558
Can anyone help please, I have been searching for vintage valve amplifier circuit diagrams and components.
I need help in finding valves, transformers, and diagrams.
I intend to build amplifiers for a rock band so i would like to build one with a 3KW output if that is feasible.
Thanks for any help no matter how little.
My honest advice is
1. Search on terms guitar amp tube circuits, it'll return scores of sites with varying degrees of credibility
2. buy a copy of RCA Receiving Tube Manual (they're all over Ebay) from mid 1960's and build the fifteen watt hi-fi amplifier in their "Projects" section in back of the book. It has great tube sound(i built it one 1963) and will make a great guitar amp. It uses the 7199 low noise preamp which will "WOW" audiophiles.
Real reason to build it is to get your feet wet. Reading the tube manual will educate you in how tube amps work so you will be able to tell the internet wheat from chaff.
Get one 1960 or newer, you'll be better able to find those not so ancient tubes.old jim
Likes davenn and berkeman
I'm away from home right now so without my books. But last year i downloaded a copy of the RCA tube manual , from an archive site. RC30 is the version i have, about 35 megabytes.
Here's that amplifier schematic
very simple, good starter project.
https://archive.org/details/RCA_RC-30_1975
its rich sound will astonish you.
Be aware though you can buy a good transistor amp with better specs for less than the cost of a 7199...
old jim
Likes Asymptotic, Dadface and davenn
unless you are an extremely experienced tech, forget building anything over ~ 100W
Jim has given an excellent example of a medium power amp in the post aboveDave
Likes Asymptotic and jim hardy
Thanks Dave
Likes davenn
Thank you for your replies, you have given me a great starting point.
Likes dlgoff, jim hardy and davenn
Jack Darr's "Electric Guitar Amplifier Handbook" (1971) is chock full of schematics, and still in print (4th edition).
Does that hifi amp have riaa EQ on the input?...assuming it's a phono input.
For a guitar amp, best not to start with a "HIFI amp" since many brochures of old HIFI amps had lines like "can pass square waves without ringing"...meaning...very little coloration of the sound.
Try www.triodeelectronics.com and check out the amp section...plenty of pictures and the site has tons of parts.
You can get the second edition from Amazon for about $50: https://www.amazon.com/dp/1461440866/?tag=pfamazon01-20
Likes Asymptotic
It's a "line level" input
Magnetic phono cartridges are barely audible through it due to their millivolt level signal. . One should precede it with a RIAA preamp and tone control for use with them.
Ceramic cartridges because they approach a volt and don't really need RIAA equalization sound pretty good through it as -is.http://www.lh-electric.net/tutorials/phono.html
Most common cartridge of the 50's and 60's was the ceramic phono cartridge. Typically, these were supplied as turnover cartridges in early (non Hi-Fi) tube and solid state stereo systems, record changers and children's players. Some were higher quality versions such as the Decca Deram. Ceramic cartridges are high impedance and high output voltage (200-1200mV) devices. Another feature of this type of cartridge is that its response is amplitude based pick-up instead of velocity based like magnetic cartridges. This means that phono equalization is not required. A record player with this type of cartridge may be plugged directly into an high impedance (tube) input. Today, this type of cartridge is best used with old 78rpm records.
Likes Asymptotic and dlgoff
@wolram - if you really think what you need are schematics of vintage tube guitar amps, there are loads of web sites that host all the schemos you could want; just start Googling; or else buy a copy of The Tube Amp Book by Aspen Pittman; it includes a CD with a massive amount of vintage schemos: https://www.amazon.com/dp/0879307676/?tag=pfamazon01-20
However from searching your profile page and your previous posts to find out how much electronics work you do, I found this recent post which suggests you are pretty much a beginner on soldering; this suggests you are also a beginner in electronics work in general: https://www.physicsforums.com/threads/lead-free-solder.901042/
If so I don't advise trying to work just from a schemo. Especially with high voltage tube amps, the circuits tend to be very noisy unless the lead dressing is very very good; and very dangerous to the end user unless constructed up to a given country's safety standards, e.g. proper strain relief for the power cord, proper means of fastening the Earth wire from the power cord to the chassis, an understanding of earthing principles, etc. etc. etc. Even experienced tube amp builders often have to troubleshoot their builds to fix problems with noise or with cold solder joints or other build problems. And working from a schemo, you'd have to design your own layout - a huge task for a beginner and one you'd probably get wrong unless you are an autodidact on the scale of Leonardo da Vinci.
Instead, from a beginner's building standpoint, I would suggest you look for and build a kit amp - a low-power kit amp to begin with. Kit makers assemble all the parts you will need & the favored designs tend to be vintage or close to vintage, e.g. a change to the schematic to ensure proper earthing. Kit makers include mainstream vendors such as Weber and Mojotone, as well as slightly smaller "boutique" vendors such as Allen Amps or Boot Hill. Note that Weber and Mojotone also sell components, along with many other vendors. Hammond (already mentioned) sells only transformers, and are very reputable; another excellent transformer source is ClassicTone. However most non-tube parts (passive, solid state, etc. ) are more cheaply obtained, and often of better quality, from industrial suppliers. In the U.S. this is chiefly http://www.mouser.com/ and DigiKey; there are surely equivalents in the U.K.
However there is a further wrinkle here. When you say this -
- what on Earth do you mean? A 3,000W output? That is meaningless in the context of tube guitar amps: club players tend to put mics on their small vintage guitar amps; the mics feed into a PA system and that is how sound reaches the audience; the amps themselves are low-watt, e.g. 15W, 25W, 50W, 100W, sometimes 200W. Some of the big stage shows such as ZZ Top do it differently; from what I've read, they tend toward advanced multi-component solid state systems to replicate the sound of small tube amps pushed into overdrive - nothing you could build yourself.
Can you state what the actual goal is in terms of what sort of rock band or bands and what you believe their needs to be and where you would fit in?
Lastly, if you're committed to exploring this further, this forum is not the place. Go to tube/SS guitar gear forums. We have EEs here, including many highly skilled builders; but guitar amps are a specialized field, so you need go to the well instead of quaffing bottled water.
The best and most accessible of the lot is The Gear Page - their home page is https://www.thegearpage.net/board/index.php and their tech page for amplifiers and speakers is https://www.thegearpage.net/board/index.php?forums/amps-cabs-tech-corner-amplifier-cab-speakers.11/ Lots of EEs and electronics techs/repair shops on the tech page, but also lots of idiots; moderators tend to intervene far less so if you ask a naive question you may get a large number of stupid replies, a large number of semi-ignorant replies, and a small amount of courteous, excellent replies. If you can ignore the stupid replies and separate the wheat form the chaff, it's an excellent source; I've gotten tons of help there. Two of their best EE members are in the U.K.; a third is in Argentina.
Also very good is Music Electronics Forum (MEF) - again, a mix of EE guitar amp buffs, plain old guitar amp buffs, small amp builders, kit builders, etc. MEF tends to be a bit more polite aside from a few crazy types, so you might like that aspect better: http://music-electronics-forum.com/forum.php Again, they have a number of U.K. members who could certainly tell you good U.K. sources for parts.
Likes Asymptotic, Tom.G, NTL2009 and 1 other person
Wow, I thought this thread was done, Thanks for all the great advice, as for my ability, I started life as an electrician and I have worked with electronics before, mainly transistor circuits. And I did get my radio armature licence, but that was yeas ago.
That would certainly make a difference. A key thing with high-voltage DC circuits crammed into tight space = lotsa noise potential! So layout is a "craft" issue as much as it is understanding how noise propagates, e.g. capacitive conductance, radiation, etc.
But if you know transistors, valve theory is "same only simpler", basically - biasing etc. One nice thing is that graphical analysis of load lines, which apparently is not useful for most semiconductor circuits, is quite useful for valves; I have done a lot of that with help from Merlin Blencowe's books & articles (see my next paragraph) and some additional tips from a couple of EEs on The Gear Page forum.
A really good source if you have interest in actual circuit design is a fellow called Merlin Blencowe, a.k.a. "The Valve Wizard", who (again) is also in the U.K.; he is an EE who at some point feel in love with valves as a hobbyist & then as an author. He's written two very nice books that very highly regarded in the valve guitar amp community, one on valve preamps for guitars and the other on valve preamps for high fidelity. I have both books & think they're terrific. I built my own small prototyping efforts at a low-voltage, single-ended guitar amp via adapting some of his example designs & also with help from tutorial articles on his website - e.g., he doesn't address the power amp section in his books, but he does have several articles on the website that walk you through how to calculate both single-ended and push-pull power amps to go with whatever preamp you build.
Here's Blencowe's website - note the "grounding" page includes a downloadable PDF which is the chapter from one book that addresses not only earthing but also noise reduction - a real treasure: http://www.valvewizard.co.uk
As for the two books - here's the guitar preamp book on amazon UK: Designing Valve Preamps for Guitar and Bass, Second Edition
And here's the hi fi preamp book ditto: Designing High-Fidelity Valve Preamps
Note that even if you are just going to do guitar amps, the hi-fi book is worth getting as it has extra chapters near the back on power supplies - many sorts of neat circuits.
Reading this thread it is quite obvious that most people here are assuming that you are talking about a guitar amplifier (=the amplifier directly connected to the guitar). These are VERY different in design than normal amplifiers since a lot (most) of the "character" of the sound of an electrical guitar comes from the amplifier. This in turns means that the amplifiers are far from "transparent" and they are usually (for rock) driven so hard that there is a LOT of distortion. This in turn explains why guitar amplifiers are usually only 5-200W (note that even a 5W amplifier can be VERY loud if you allow it to distort). This also means that there is not "correct" way to build a guitar amp; it is just personal preference.
3kW would be more typical for a large PA system where you need a "clean" signal to amplify the whole band and also need a lot of headroom for EQ, feedback cancellation etc. However, modern PA amplifiers are -AFAIK- never built with valves. Back in the "olden" days before the advent of transistors they simply did not have very powerful amplifiers (for sound) which is why they sometimes ended up using large horne-based speakers; the latter have high sensitivity meaning you don't need a lot of power.
You are right about everything you say; however I thought I would expand just a bit on this one point. Of course someone building from scratch can do whatever they like; but probably they're going to end up (a) learning by necessity about the craft of valve audio circuits, and (b) borrowing from historically well-known valve guitar amp designs.
Regarding (a), there is a known body of craft that will help someone designing, building, or repairing valve audio amplifiers, whether for guitar or hi-fi. The craft for valves differs in particular ways from that for solid state, so even a good SS designer will have to learn some new things.
As for (b), as you have already indicated, there is a tradition going back by now for over 60 years if not longer of valve circuits being designed & built for very particular sounds that both guitarists and their audiences are now accustomed to hearing & preferring - see for example this page on "10 Classic Guitar Amps & Their Sounds." Typically the sound is shaped by how much clipping, and what type, is going on or not going on in the preamp; ditto the power amp; how much abuse the output transformer and speakers are getting; also various flavors of passive filters; plus finally the interaction of all of this with the different sorts of electric guitar pickups and different sorts of pedal effects. When the OP asks for "vintage" schematics, he is in effect nodding toward this long history of existing preference on the part of rock guitarists and audiences for these sorts of circuits. You can of course mix and match different flavors of preamp and power amp - that's what I've done myself.
What's interesting is that way back when Leo Fender was building his first designs, he apparently did a lot of unorthodox things - e.g. reasonably quiet lead dressing was achieved not by following best practices, but via endless trial and error. Same with VOX, Marshall, and many other companies that did the early designs that are now copied and repeated, including repetition via solid state and digital emulator circuits. Part of this is that if distortion (clipping) is good, many designs that would have flunked the standards of the old valve hi-fi stereo companies got by just fine in Leo's hands - if I remember, he was just a small-time radio repair guy when he started out.
The little world of valve guitar amps is neat in a way, and claustrophobic in other ways. The belief that valve guitar amps have a special sound that is superior to solid state is a fetish among many guitar enthusiasts - especially those who don't know much about electronics, and who share with each other myths and misconceptions about valves, transformers, capacitors, etc. etc. Meanwhile, there is virtually no work being done by anyone to invent valve guitar amplifiers that produce new kinds of sounds. Solid state, MIDI, digital platforms such as Ableton, and to some extent digital pedals have taken over the task of inventing new sounds.
That's how the reflex design came about. When 15 watts from push-pull 6V6's was considered a lot of power the audio guys figured out how to make the sound from the back side of the speaker cone come out the front of the enclosure and reinforce not cancel that from its front..
Search on Reflex Speaker Enclosure, Thiele, and "Electro Voice" . There are some fascinating papers out there.
Also the classic 1940 RCA book on "Acoustics"
https://www.google.com/search?q=1940+book+"Acoustics"+.&ie=utf-8&oe=utf-8
@Planobilly made good use of this forum doing it. e.g. https://www.physicsforums.com/threads/my-latest-crazy-amp-project-photos.894868/ and https://www.physicsforums.com/threads/new-amp-build-photos.891627/
just sayin'
Likes jim hardy
dlgoff said:
just sayin'
I dislike this particular bit of slang: it implies a criticism without making clear what it is.
If you think I was taking a dig at folks here on the EE forum, you're wrong. I know about Planobilly. This forum can be and has been of great use, and is always a good place to start if you're already on it. I often start on PF with questions I know will eventually lead me elsewhere. But do you object to referring an OP with a specialized question to a specialized forum? Did you look at the forums I mentioned to see what they have to offer? What exactly is the objection?
If a criticism was meant, please make it clear. If none was meant, why not drop the slang next time? That phrase is used a lot on forums that are less well-moderated than this one, and it usually goes along with trading digs and insults and driving down the quality of an otherwise helpful thread.
Threads closed briefly for Moderation.
Yes, in general the Mentors delete and PM a poster who advertises another discussion forum in their PF posts. In this case I'll let your post stand.
A better alternative would have been to make that recommendation in a PM to him. That way they learn about good other specialized forums, but it doesn't look like you are posting advertising to competitive forums here.
Thread re-opened for any more on-topic replies. :smile:
To me, phrase "just sayin" implies comfortable nonconfrontational intent by a speaker.
I guess we all have our "sensitive" buttons.
old jim
Likes davenn
Ahem...
Likes jim hardy
Sorry you took it that way. No criticism intended. The portion of your post I quoted was entirely for the benefit of the OP. I didn't know if Wollie had ever seen @Planobilly's build.
Likes berkeman
Thanks for clarifying. I'm sorry I over-reacted. I do have a thin skin on certain points, based on history elsewhere.
Likes dlgoff, berkeman and jim hardy
Just to add my 1.5c there are sites all over the Internet with circuit diagrams of Marshalls, Fenders, Voxs etc. Many of the modern versions don't actually differ much from the originals, they've just added more channels or put midi-control on the switching etc. Also many amps are just copies of someone else's. You just have to decide whether you want Class A or A/B or whatever. The circuits are simple but getting exact replicas of things like output transformers may require custom work. If you are happy with more modern versions they are available as spares from the current manufacturer.
Cheers
I built a 30W guitar amp many years ago. Here's the circuit:
  • ELE valve 30W guitar amp.pdf
Related to Help with finding vintage valve amplifier circuits (amplifiers for a rock band)
1. How do I find vintage valve amplifier circuits for my rock band?
To find vintage valve amplifier circuits for your rock band, you can start by searching online for websites or forums that specialize in vintage audio equipment. You can also visit local music stores or pawn shops that may have vintage amplifiers for sale. Additionally, attending vintage audio equipment trade shows or conventions can be a great way to find rare and unique valve amplifier circuits.
2. What are the benefits of using vintage valve amplifier circuits?
Vintage valve amplifier circuits are known for their warm and rich sound quality, making them a popular choice among musicians. They also have a unique and distinct tone that cannot be replicated by modern amplifiers. Additionally, vintage amplifiers are often built with high-quality components and have a longer lifespan compared to newer models.
3. How can I ensure that the vintage valve amplifier circuit is in good working condition?
Before purchasing a vintage valve amplifier circuit, it is important to do your research and ask the seller about the condition of the amplifier. You can also ask for a demo or test the amplifier yourself to check for any potential issues. It is also recommended to have a professional technician inspect the amplifier before making a purchase.
4. Are vintage valve amplifier circuits expensive?
The cost of vintage valve amplifier circuits can vary greatly depending on the brand, model, and condition. Some may be more affordable, while others can be quite expensive. It is important to set a budget and do some research to find the best deal for your needs.
5. Can I use a vintage valve amplifier circuit for other genres of music besides rock?
While vintage valve amplifier circuits are commonly used in rock music, they can also be used for other genres such as blues, jazz, and even country. The unique sound and tone of these amplifiers can add character and depth to any type of music. It ultimately depends on personal preference and experimentation to see what works best for your sound.
  • Electrical Engineering
  • DIY Projects
