Help with force and friction on a flat surface
To determine the minimum force needed to prevent a 30kg crate from moving under a 125N pull, the relationship between static friction and normal force must be understood. The static friction force can be calculated using the coefficient of static friction (0.34) multiplied by the normal force. The normal force is equal to the weight of the crate (294.3N) plus any additional force applied downward. To stop the crate from moving, the total static friction must equal the pulling force, which means the normal force must be adjusted accordingly. Understanding this relationship is crucial for solving the problem effectively.
Mattches
I have a 30kg crate on a flat floor. There is a rope pulling the crate to the right with a force of 125N. The coefficients of static and kinetic friction are .34 and .24 respectively. I need to know what the minimum force I could put on top of the crate to stop it from moving.
Fg = 9.81 m/s^2
uS = .34
uK = .24
m = 30kg
I know that I need to use Newtons second law to determine the sum of all forces in each direction, and see how much needs to be added to overcome the 125N pull. But honestly I have no idea where to start!
I know that Fg on the crate is 294.3N. And I know that friction opposes the way the crate is being pulled. But I really don't know how to piece this problem together.
Can anyone help?
What must the total static friction be to keep the crate from moving? (Assuming it is initially at rest.)
How is max static friction related to the normal force between crate and floor?
The total static friction has to be equal to the force pulling the crate. The normal force is pushing the crate up at the same rate that gravity is pulling down but...I'm still not exactly sure where to go from there. Sorry but I'm very new at this :[
Good.
That would be true if you didn't apply any additional force on the crate. But whatever force you push down on the crate with will add to the normal force.
How does static friction relate to the normal force? Use that fact (and your first statement in this post) to figure out what the total normal force needs to be for there to be enough friction.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
