How Do You Solve for Variables in Vector Addition Equations?
To solve for the variables a and b in the vector addition equation aA + bB + C = 0, the components of the vectors must be set to zero. This results in two simultaneous equations derived from the i and j components: 6a - 8b + 26 = 0 and -8a + 3b + 19 = 0. The discussion highlights the need for both equations to find unique values for a and b, as there are infinitely many solutions without them. The user initially guessed a = 5 and b = 7, but sought an algebraic method to derive these values. Ultimately, the equations can be solved using standard algebraic techniques to find the correct magnitudes of a and b.
DoktorD
Given:
\vec{A}=(6.0\hat{i} - 8.0\hat{j})
\vec{B}=(-8.0\hat{i} + 3.0\hat{j})
\vec{C}=(26.0\hat{i} + 19.0\hat{j})
If aA+bB+C=0, what are the magnitudes of a and b?
a(6.0\hat{i} - 8.0\hat{j}) + b(-8.0\hat{i} + 3.0\hat{j}) + (26.0\hat{i} + 19.0\hat{j}) = 0
I know that's the set up of the equation, but I have no idea how to solve for a and b. Shouldn't there be a second equation to give the relationship between a and b or else there's an infnite number of solutions? Just by looking at it for a few periods, I saw that a = 5 and b = 7 works, but I can't figure out how to reach that answer using algebra!
Well you will get two equations. To get the zero vector both i and j components have to be zero.
OK, but the thing is what method would be used here to find those two variables? What strategy would be used?
Nevermind, I got it
You have:
a(6\mathbf{\hat{i}}-8\mathbf{\hat{j}})+b(-8\mathbf{\hat{i}}+3\mathbf{\hat{j}})+(26\mathbf{\hat{i}}+19\mathbf{\hat{j}}) = (6a-8b+26)\mathbf{\hat{i}} + (-8a+3b+19)\mathbf{\hat{j}}=0
For that to equal zero both i and j components must equal 0, so you have 2 simultaneous equations.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
