Analyzing an Elastic Collision Between Two Hockey Pucks
  • Thread starter Thread starter nsaZn23
    Momentum
An elastic collision between two hockey pucks is analyzed, where one puck moves at 0.43 m/s and collides with a stationary puck. After the collision, the first puck is deflected at 35° with a speed of 0.36 m/s. The discussion emphasizes the importance of using conservation of momentum rather than energy for solving the problem. Participants discuss breaking down the velocities into components to find the speed and direction of the second puck. Ultimately, one participant successfully solves the problem after seeking clarification on the approach.
nsaZn23
A hockey puck moving at 0.43 m/s collides elastically with another puck that was at rest. The pucks have equal mass. The first puck is deflected 35° to the right and moves off at 0.36 m/s. Find the speed and direction of the second puck after the collision.
1/2mv2 + 1/2mv2 = 1/2mv2 + 1/2mv2
momentum initial = momentum final
no idea
Start by putting the equations for initial momentum and final momentum.
m \vec{v_{1}} + m \vec{0} = m \vec{v_{1}}' + m \vec{v_{2}}'
then set up the KE equations too
no idea
This would be an elastic collision.
http://en.wikipedia.org/wiki/Elastic_collision#One-dimensional_Newtonian
You would want to focus on the conservation of momentum, not the conservation of energy.
In this regard you need to identify the components of the x,y velocity and add them separately to determine the components of the one you don't know. Then recombine the components to give the right answer.
uhhh I'm bad at physics can you elaborate?
nsaZn23,
are you familiar with vectors?
the problem basically is
v_{1} \vec{i} + \vec{0} = v_{1}_{x}' \vec{i} + v_{1}_{y}' \vec{j} + v_{2}_{x}' \vec{i} + v_{2}_{y}' \vec{j}
Yeah,
I see that Mass X Velocity initial1 + Mass X Velocity initial2 = Mass X Velocity Final1 + Mass X Velocity Final2.
nevermind, i figured out how to do the problem, thanks.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
