Homework problem: Consider the transformation
Jamin2112
Homework problem: "Consider the transformation ... "
1. Consider the transformation x=u2+v2 and y=u3+v3.
(a) Check that the Jacobian equals 0 on the line v=u and on the u-axis and on the v-axis.
(b) Show that the transform of the line v=u is the curve 2y2=x3, and that the transformation of the u-axis and v-axis form the curve y2=x3. Draw those curves.
(c) Find the regions in the u-v plane where the Jacobian of the transofmation is positive and the regions where the Jacobian is negative.
(d) Show that the transformation is 2:1 to the region in the x-y plane inside the curve 2y2=x3, and is 4:1 to the region in the x-y plane between the curves 2y2=x3 and y2=x3, using the sign information for the Jacobian in (c) and the fact about the direction of motion just cited.
Suppose that the transformation transforms some circle about a point P in the u-v plane into a loop about the image of P in the x-y plane, and that the region inside the circle is transformed into the region inside the loop. We will show in class that, at a point on the circle where the Jacobian of the transformation is positive, when you move counterclockwise about the circle, then you are moving counterclockwise about the image loop.
(a), (b), and (c) were a cinch. Just so you know, my graph on (c) is the line u=v in the u-v plane. I indicated that the Jacobian was positive in quadrant 4 and negative in quadrant 2; and that in is positive in top slice of quadrants 1 and 3 and negative in the bottom slice of those same quadrants (I hope that makes sense!).
Anyways, (d) is giving me trouble. I can graph the regions in the x-y plane pretty easily, but not the corresponding regions in the u-v plane. For example, I want to show that the region inside 2y2=x3 goes to two different regions in the in the u-v plane. It's getting really complicated and annoying.
2(u3+v3)2=(u2+v2)3
2(u6+2u3v3+v6)=(u4+2u2v2+v4)(u2+v2)
2u6+4u3v3+2v6=u6+2u4v2+u2v4+u4v2+2u2v4+v6
u6+4u3v3+v6-3u4v2-3u2v4=0
... and I don't even know if I did that right. Or if I'm doing this problem the right way.
Help, please.
I have another question---since I know you guys are intelligent and helpful.
One question asks: Find the transforms of the two rays that bound that chamber in (b), and tell what is the image of the transformation
I have never heard of a "ray" or "chamber." What the fork?!?
*bump*
*bump*
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
