How to Determine Maximum Tension Before a Rubber Band Snaps?
To determine the maximum tension a rubber band can withstand before snapping, one can start by applying the formula T = mg to calculate the force exerted by the suspended mass. Additionally, Hooke's Law (F = k/λ) can be used to find the spring constant, but it's important to note that this constant changes as the rubber band is stretched and thinned. As the rubber band approaches its breaking point, the ultimate tensile strength comes into play, and the spring constant will vary significantly due to molecular bonds beginning to break. If the mass is bouncing, the tension increases due to the acceleration, which can lead to a higher likelihood of snapping. Understanding these dynamics is crucial for accurately assessing the rubber band's limits.
~Josh [G]
Hi, I just have a problem dealing with the background of a project I am working on in physics...
I basically have a rubber band fixed at a point above the ground, from which I have masses suspended from it. So obviously, as I add more mass, the elastic is strained more and more, and stretches to a point where it finally just snaps. Anyhow, in this particular situation, how exactly would I figure out the maximum tension (or ultimate strength) before it fractures? Is it just a matter of T=mg? Or F = k/\L? (Hookes law) if you argue that elastics are considered springs...in which case, how would I determine a constant of proportionality?
thanks
You use F = mg to find out what Force you've applied to the band.
You can "try" to use F = k/\L to determine the k - value for the band.
As you stretch the material, the "spring konstant" will gradually change
(it is getting thinner, so the Pressure = F / cross-section Area changes).
As you get CLOSE to breaking it - the "Ultimate Tensile Strength" -
k will start to change drastically (some molecule bonds ARE breaking).
oooh so is it safe to say tension = F applied up until the elastic breaks?
well, if the mass is bouncing, then its acceleration is nonzero.
But if a=0 , then the hanging thing has mg (down) and T (up) only.
The elastic will be more likely to break if the hanging thing bounces,
because its Temperature will cycle rapidly (bad for macromolecules).
