How Can a Balloon's Volume Increase When Cooled?
The discussion centers on a balloon's volume change when cooled from 90°F to 30°F, where the pressure drops from 20 lb/in² to 14.2 lb/in². Despite the expected contraction from cooling, the pressure drop causes the balloon to expand, resulting in a calculated volume of 0.31 m³, which is larger than the original volume. Participants note that the problem's parameters may not reflect realistic conditions, as a significant pressure drop inside the balloon is unlikely when cooled in a refrigerator. The ideal gas law calculations are confirmed as correct, but the scenario presented raises questions about its feasibility in real-world applications. Ultimately, the balloon's behavior in this problem illustrates the complex interplay between temperature and pressure in gas laws.
nicksim117
On a warm day 90F, the air in aballon occupies a volume of .25m3 and exerts a pressure of 20 lb/in2. If the baloon is cooled to 30F in a refrigerator, the pressure drops to 14.2lb/in2. What is the volume of the balloon
P1xV1/T1=P2xV2/T2-----((P1xV1)/T1)xT2/P2
T1=305.2K
T2=271.88K
.31m3 is the answer i keep getting How is this possible when this volume is larger than the original.
You've got two competing effects here. First, there's a temperature drop, which tends to make the balloon shrink. But you've also got a pressure drop, which tends to make it expand. It just so happens here that the effect of the pressure drop dominates the effect of the temperature drop, hence you have a larger balloon.
But the pressure drop is inside the balloon.
There is no way you are going to have a larger balloon when you cool it down in a freezer.
What values did you use for T1 and T2? In the ideal gas law, termperatures must be given in degrees Kelvin.
I listed them in the problem T1 305.2 T2-271.88
Yes that's true. And how that pressure drop is achieved, I do not know as the problem doesn't say. All I know is that under the temperature and pressure drops given in the problem statement, you do in fact get a larger volume.
It could be that the data given in the problem is unrealistic, but your calculation is nonetheless correct.
I suspect this is yet another case of someone making up a problem without checking to see if the given information makes sense in terms of a natural process. I don't really believe that the pressure in the balloon would drop to that value by chilling it in the fridge that way. However, the answer of 0.314 m^3 is what you get from the ideal gas law using that information. (Yeah, right: I want to see how they got a balloon with a diameter over 60 cm. into the refrigerator to start with... Maybe it's a "walk-in"...).
The point is that, for the purposes of this problem [grinds teeth], the balloon would have to have expanded and cooled from its initial state in order to reach that final state. You did the problem right -- it's not your fault it makes little sense...
Your answer is correct.
The problem here is that you are imagining that this is occurring in the real atmosphere. It isn't.
If the atmospheric pressure was held constant (i.e as in the real atmosphere), when the temperature decreases the internal pressure decreases and the balloon volume is reduced until the pressure inside balances the atmospheric pressure + pressure of the balloon material. This is what you are imagining is occurring. But it isn't. In this problem you end up with a lower pressure.
In the problem, you have a balloon at 90F experiencing a reduction in the external pressure from 20 lb to 14.2 This will result in expansion of the gas and, therefore, cooling. In fact, the expansion due to pressure reduction will result in the gas cooling to even less than 30 F. So in the problem, heat actually flows into the balloon.
AM
