How can I demonstrate that the integral of vdP is used to calculate work in flow machines?
The discussion revolves around the application of the integral of vdP in calculating work in flow machines, contrasting it with the more familiar PdV expression used in cylinder-piston systems. Participants explore the context of flow systems and specific cases such as compressors.
  • One participant expresses confusion about why work is represented as the integral of vdP instead of PdV, as typically seen in cylinder-piston exercises.
  • Another participant questions whether the system in discussion is a flow system, providing the example of a nozzle to clarify the context.
  • A participant mentions that the professor indicated the expression w = ∫ vdP is used for flow machines, specifically in the context of a reversible compressor undergoing a polytropic process.
  • It is noted that for a differential section of the compressor at steady state, the first law of thermodynamics can be expressed as dWs = dh - Tds - vdP, leading to the conclusion that for adiabatic reversible operation, ds = 0 results in dWs = vdP.
Participants do not reach a consensus on the use of vdP versus PdV, with some agreeing on the applicability of the former in flow machines while others remain uncertain about the transition between these expressions.
The discussion includes references to specific thermodynamic principles and the context of flow systems, but lacks detailed mathematical derivations or assumptions that could clarify the transition between the two expressions for work.
This discussion may be useful for students and professionals interested in thermodynamics, particularly those studying flow machines and the application of work calculations in engineering contexts.
Emmanuel S
I have this little doubt because in class, the professor said the work is equal to the integrate of vdP, but i don't know how to prove it, why it isn't PdV like those exercises in a cylinder-piston
Is your system a flow system, such that fluid is flowing into the system and out of the system through inlets and outlets to a control volume? An example would be a nozzle.
Indeed. In fact, the problem was with a reversible compressor; the process was polytropic, and after performing the mass and energy balance, when calculating the compressor's specific work, the professor established w = ∫ vdP
And he said that for flow machines, the work took that expression, not PdV.
from Moran, et al, Fundamentals of Engineering Thermodynamics I saw the balance explained
For a differential section of the compressor operating at steady state, the open system version of the first law of thermodynamics tells us the $$dW_s=dh=Tds-vdP$$ where h is the enthalpy per unit mass of gas, s is the entropy per unit mass, v is the volume per unit mass, and ##W_s## is the shaft work. For adiabatic reversible operation, ds = 0, so $$dW_s=vdP$$
  • · Replies 19 ·
  • · Replies 45 ·
  • · Replies 35 ·
38K
  • · Replies 48 ·
