How do I calculate the tension in cable 1 without using the tension in cable 2?
  • Thread starter Thread starter ijd5000
    Tension
The discussion focuses on calculating the tension T1 in cable 1 of a chandelier without relying on the tension T2 in cable 2. The user derives two equations based on the forces acting on the chandelier: F(x) and F(y). By manipulating these equations, specifically by dividing the equations for the x and y components, the user successfully eliminates T2, leading to an expression for T1 in terms of the chandelier's mass m, angles θ1 and θ2, and the acceleration due to gravity g. This method demonstrates the effective use of trigonometric identities in solving for unknown tensions in a static equilibrium scenario.
  • Understanding of static equilibrium and forces
  • Knowledge of trigonometric functions and identities
  • Familiarity with Newton's laws of motion
  • Basic algebra for manipulating equations
  • Study the principles of static equilibrium in physics
  • Learn about vector decomposition in force analysis
  • Explore applications of trigonometric identities in physics problems
  • Investigate tension calculations in different mechanical systems
Physics students, engineers, and anyone involved in mechanical design or structural analysis who needs to understand tension calculations in static systems.
ijd5000
A chandelier with mass m is attached to the ceiling of a large concert hall by two cables. Because the ceiling is covered with intricate architectural decorations (not indicated in the figure, which uses a humbler depiction), the workers who hung the chandelier couldn't attach the cables to the ceiling directly above the chandelier. Instead, they attached the cables to the ceiling near the walls. Cable 1 has tension T1 and makes an angle of θ1 with the ceiling. Cable 2 has tension T2 and makes an angle of θ2 with the ceiling.
Find an expression for T1, the tension in cable 1, that does not depend on T2.
Express your answer in terms of some or all of the variables m, θ1, and θ2, as well as the magnitude of the acceleration due to gravity g.
i have for my Forces:
F(x) T2 cos ( θ2)-T1cos(θ1)=0
F(y) T2 sin(θ2)+T1 sin(θ1)-gm=0
not sure how to describe T1 without using T2
These are two equations in two unknowns, T_1 and T_2.
If you write them as
T_1cos(v_1)=T_2cos(v_2)
T_1sin(v_1)-mg=-T_2sin(v_2)
then dividing the one equation with the other yields:
[tex]\frac{T_{1}\sin\theta_{1}-mg}{T_{1}\cos\theta_{1}}=-\tan\theta_{2}[/tex]
Hurray, T_2 has disappeared! :smile:
Now, rearrange the last equation, so as to solve for T_1
It's ok to combine equations from different directions? I thought you have to keep x and y separate until you add the vectors.
27K
14K
