How do I find final velocity using conservation of energy
The discussion revolves around a physics problem involving a paintball gun launching a paintball off a cliff at an angle of 45°. The cliff height is 165 m, and the initial velocity of the paintball is 180 m/s. Participants are attempting to calculate the speed of the paintball upon impact with the ground using conservation of energy principles.
  • Participants discuss the calculation of kinetic and potential energy, questioning the use of the x-component of velocity in determining height. There is an exploration of how to find total energy at the initial time and whether to consider it as potential energy before launch. Some participants suggest checking the total energy at the start and comparing it with the energy at maximum height.
The discussion is ongoing, with participants providing insights into energy conservation and questioning the assumptions made in the calculations. Some guidance has been offered regarding the relationship between kinetic and potential energy, and the importance of using magnitudes in energy calculations. Multiple interpretations of the problem setup are being explored.
Participants are navigating potential misunderstandings regarding the application of energy conservation principles and the definitions of kinetic and potential energy in the context of the problem. There is a focus on ensuring clarity in the use of components of velocity and their implications for energy calculations.
Alameen Damer
A paintball gun launches a paintball off a cliff at an angle of elevation of 45°. The cliff is 165 m high. The paintball is initially moving at 180 m/s. Calculate the speed of the paintball as it hits the ground. I'm having trouble understanding how to solve this, I have posted my attempt.
Ek=1/2mv^2
Eg=mgh
I'm going to find the kinetic energy using the initial velocity.
So, cos 45 x 180 = 127.3 m/s. <---- This is velocity in the x direction
Ek=1/2 m *(127.3)^2
=8102.6m
Find height by subbing this into the Eg formula:
8102.6m=mgh
8102.6=9.8h
826.8=h
So this is the height of the projectile, in reference to the cliff. The total height however should have the 165m of the cliff added: Therefore it is (826.8+165)=991.8 m
This is the maximum height, I will use it to find the total energy at max height, so
Eg=991.8gm
=991.8(9.8)m
=9719m
Now I sub this into Ek to find the Velocity.
Ek=9719m
1/2mv^2=9719m
1/2v^2=9719
v^2=19439
v=139 m/s
The book answer says 190 m/s.
Using the x component of velocity to find a height? (It doesn't make a difference mathematically since the angle is 45 degrees, however typically we the x-axis is horizontal) I would have written this off as a typo but you used cosine as well.
Eg=991.8gm
=991.8(9.8)m
=9719m
The total energy of the system should not change, correct? Check what the total energy was at t=0 and compare it with this.
I used cosine because I was trying to find height at the maximum point, where no forces act along the x direction. How can i find total energy at t=0, do i consider it as potential, (before launch)?
CosӨ gives the relationship between the x component of the velocity and the original velocity.
EDIT: I should specify that this is only the case when the angle is between the horizontal and the hypotenuse, which is the case in this question.
Heights correspond to the y-axis unless you've switched them for some reason. But since you didn't explicitly state it I assume your going with the convention that X is horizontal and Y is vertical.
Alameen Damer said:
How can i find total energy at t, do i consider it as potential, (before launch)?
Add kinetic and potential energy using the initial conditions.
Ek=1/2mv^2
Eg=mgh
Ek=1/2 m *(127.3)^2
=8102.6m
8102.6m=mgh
8102.6=9.8h
826.8=h
Eg=991.8gm
=991.8(9.8)m
=9719m
Ek=9719m
1/2mv^2=9719m
1/2v^2=9719
v^2=19439
v=139 m/s
Remember that energy is a scalar quantity, so we want to use the magnitude of the velocity as our ## v_i ## and our ## v_f## instead of ##(v_x)_i##, ##(v_y)_i## ##(v_x)_f## and ##(v_y)_f##. Also, this equation may help you solve this problem: ## \Delta{E} = E_f - E_i = 0J ## What are ## E_f ## and ## E_i ##?
It also helps to solve your problem in terms of variables, check the units to see if they match up with velocity's units, and only then plug in given values! If you become competent at solving problems generally, it will trivialize solving problems individually. You may also recognize the equation you find when solving generally... :)
