How do mass affect the acceleration of a pulley?
Mass directly affects the acceleration of a pulley system due to the principles outlined in Newton's second law, which states that an unbalanced force is required for acceleration. In a pulley setup, if one mass is greater than the other, it creates an unbalanced force that causes acceleration. The direction of the force is altered by the pulley, allowing the heavier mass to accelerate downward while the lighter mass is pulled upward. Analyzing the system through free body diagrams can clarify the forces at play. Understanding these concepts is essential for accurately explaining the relationship between mass and acceleration in a pulley system.
boii
Hi, i am doing physics 20 and i am still quite new at this stuff. I have a base understanding of how the mass affect the acceleration but i can't find a way to explanation of why the the mass affects the acceleration by making it faster or slower of a pulley for my lab like this one http://cnx.org/content/m14060/latest/fap1.gifAnd i believe Newton 2nd law has to do something as well but i don't understand it if there's no force applied how acceleration could be found? If anyone could help me with this thanks!
Welcome to PF;
Without an unbalanced force, there is no acceleration.
In the example you give, there is an unbalanced force. The weight on one side of the pulley is greater than the weight on the other.
The effect of the pulley is to change the direction of action of the force ... draw a free body diagram for each component of the setup just like you'd normally do.
Assume the pulley itself is negligible mass and negligible friction.
Intuitively first, you would expect the heavier to mass to accelerate down pulling the smaller mass up. Look at three limiting cases:
1) m2 >> m1
2) m2 = m1
3) m2 << m1
So for the case where m2 = 2*m1 you are somewhere between the limiting cases 1) and 2).
m2 > m1 = 2*m1
This statement is nonsense.
m1 ≠ 2*m1 ...
I can see what you are trying to do ... but how about letting OP do the fbd's first?
