How do you calculate finge width without the wavelength ?
  • Thread starter Thread starter AJ786
    Wavelength Width
To calculate fringe width without knowing the wavelength, the discussion focuses on using the fringe spacing formula Y = D(lamda) / d. Given the distances across 20 fringe spacings at two different screen distances, the fringe widths were calculated as Y1 = 2.90 mm and Y2 = 3.70 mm. The wavelength for each setup was derived using the formula, resulting in (lamda)1 = 4.80 mm and (lamda)2 = 9.60 mm. The calculations demonstrate how to relate fringe spacing to screen distance and slit separation. This method allows for the determination of wavelength indirectly through measured fringe patterns.
AJ786
Young's fringes, produced by monochromatic laser light passing through slits 0.60mm apart, are viewed on a screen. The distance accrose 20 fringe spacings on the screen is 58mm. When the screen is moved 0.80m away from the slits, the distance across 20 fringe spacings becomes 74mm.
Y = D(lamda) / d
Y = Fringe Spacing
D = Distance from slits to screen
d = spacing between slits
(lamda) = Wavelength
Y1 = 58mm / 20 = 2.90mm Y2 = 74mm / 20 = 3.70mm (lamda)1 = Y1D1 / d (lamda)1 = 2.90(0.8) / 0.60 (lamda)1 = 4.80(lamda)2 = Y2D2 / d (lamda)2 = 3.70(1.6) / 0.60 (lamda)2 = 9.60
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
