How Do You Calculate Force on an Orifice Plate in Fluid Mechanics?
The discussion focuses on calculating the force on an orifice plate in fluid mechanics using the Bernoulli equation and the Reynolds transport theorem. The user initially applies the Bernoulli equation, p1 + 0.5ρv1² = patmos + 0.5ρv2², and attempts to derive the force using the momentum balance equation, m(v2-v1) + p1A1 = PatmosA2 + Fx. A key correction identified in the discussion is the incorrect signs on some terms in the momentum balance, which affects the calculation of the force (Fx).
  • Understanding of the Bernoulli equation in fluid dynamics
  • Familiarity with the Reynolds transport theorem
  • Knowledge of mass flow rate calculations (m = ρAv)
  • Basic principles of momentum balance in fluid mechanics
  • Review the application of the Bernoulli equation in various fluid flow scenarios
  • Study the Reynolds transport theorem in detail for fluid mechanics applications
  • Learn about momentum balance and its implications in fluid systems
  • Explore common mistakes in fluid mechanics calculations and how to avoid them
Students in fluid mechanics courses, engineers working with fluid systems, and anyone involved in calculating forces on orifice plates in practical applications.
Jsp83
<<Moderator note: Missing template due to move from technical forum.>>
I am having difficultly with a problem in my fluid mechanics course and I'm hoping someone could help me out.
Here is a screenshot of the question I'm stuck on:
So far I have been using Bernoulli equation to find the pressure in the pipe, assuming atmospheric pressure at the point where the stream is released. This gives p1 + 0.5ρv12 = patmos + 0.5ρv22
Where v2 = v1A1/A2
I have then been using the Reynolds transport theorem to find the force on the plate:
Where m is the mass flow rate, m = ρAv1
and Fx is the force I am solving for.
Can anyone find anything wrong with this method, as I have checked my calculations many times but constantly get the wrong answer.
Thanks in advance
The signs on some of the terms in the momentum balance are incorrect.
m(v2-v1)= (sum of forces in +x direction) - (sum of forces in -x direction)
Chet
Ah, so obvious now... thanks for your help
  • · Replies 20 ·
  • · Replies 45 ·
  • · Replies 22 ·
  • · Replies 84 ·
9K
  • · Replies 16 ·
