How Do You Calculate Speed and Uncertainty with Given Measurements?
  • Thread starter Thread starter Alipepsi
    Uncertainty
To calculate speed and uncertainty, the formula v = d/t is used, where distance is 228 cm with an uncertainty of ±0.5 cm and time is 2.99 s with an uncertainty of ±0.5 s. The user conducted 15 trials, yielding a total speed of 44.99 s, leading to an average speed of 2.99 m/s. The user attempted to calculate the percentage uncertainties for both distance and time, resulting in confusion over the final speed calculation. Assistance is sought to clarify the correct method for determining speed and its associated uncertainties.
Alipepsi
Hey there, I need some help with uncertainties and how to find the speed of a moving object. I have tried to solve the problem several times but my answer seems to be wrong.
Formula for speed : v=d/t
My uncertainties: 0.5cm (distance) and 0.5s for time. The uncertainties were measured with the same analog.
I did the experiment 15 times and got different speed result of the object each time. The total sum of the speeds ( 15 trials) was 44.99s. The average of that is 2.99 (15/44.99)
Oh and my measuring device was 228cm long (exact)
I need to find out the speed and the uncertainties
If I missed any detail please please let me know
PLEASE HELP! I'am very frustrated right now..=S
Formula to use : v=d/t
v=d/t
= (228 +\- 0.5)m/(2.99+\- 0.5)s
228 divided by 0.5 = 456%
2.99 divided by 0.5= 5.78%
456% +5.78%=461.98%
so now 461.98% * 76.2 ( which I got by diving 288 and 2.99)
my final answer was v=76.25m? +\- 39%..
I'am confused..
Actually spend hours on trying to solve this :S
Help will be greatly appreciated!
anyone?
Check out this site here: http://www.rit.edu/cos/uphysics/uncertainties/Uncertaintiespart2.html
Okey, thanks
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
