How Do You Calculate the Area Bounded by \( r = 8\cos(10\Theta) \)?
Cici2006
Find the area of the region bounded by r=8cos10\Theta
I set r=0 to find \Theta, which i used for my bounds
\Theta=pi/20, 3pi/20
A= \int(1/2)64cos^2(10\Theta) d\Theta
What you need to do is multiply your answer by 20 since you found the area of one of the 20 petals of the rose curve.
Are you having trouble finding the correct solution since yours is too small? or because you don't know how to evaluate the integral?
If you need help evaluating the integral, use the fact that
\cos^2{nx} = \frac{1+\cos{2nx}}{2}, n\in\mathbb{N}
Okay, let me state what i did in more detail:
A=(1/2)integral 64(cos^2(10theta)) d(theta)
=32 integral (1/2)(1+cos20theta) (theta)
=16[theta-(1/20)sin20theta]
did i do it correct so far?
then i just plug in my bounds which are pi/20 to 3pi/20 right?
now should i just multiply my answer by 20?
thanks for the help i solved it
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
