How do you convert 3 Volt Control signal to 5 Volt control signal
To convert a 3-volt control signal to activate a 5-volt relay, using an NPN transistor like the 2N2222 is recommended, as it can handle the current requirements better than a simple logic gate. The relay's input coil resistance and current draw at 5 volts are crucial for proper operation, but this information is often missing from product specifications. A 1k Ohm resistor is suggested between the control signal and the transistor's base to limit current, ensuring the transistor operates effectively. The base resistor value is determined by the transistor's current gain (Beta), which dictates the relationship between base current and collector current. Proper calculations for power dissipation and saturation voltage are essential for ensuring the transistor functions within its rated limits.
hirochiamaru
I have a data acquisition device that outputs 3 volts if the sensor is activated. My relay only activates when a 5 volt source is put across the coil. What is the easiest way to step up the 3 volt control signal.
Welcome to the PF. The answer to your question depends a bit on the current requirement for your 5V relay. Even small 5V relays typically require more current than a simple logic gate can produce. It is common to use a relay driver IC, or to have your logic gate drive an NPN pull-down transistor that sinks current down through the relay.
Are you familiar with these two other alternatives for driving relays? The transistor version is shown here for example:
http://www.dnatechindia.com/index.php/Tutorials/8051-Tutorial/Relay-Interfacing.html
I have not tried a relay driver IC but the transistor method looks promising. I just have a couple questions.
I got the relay at radio shack.
http://www.radioshack.com/product/i...&sr=1&origkw=relay&kw=relay&parentPage=search
# Maximum switching current of 0.5 A
# Maximum initial contact resistance of 150m ohms
1. My data acquisition device can't supply more than 20ma at 3.2V. Can a 2n2222 NPN transistor work for the same circuit in
http://www.dnatechindia.com/index.php/Tutorials/8051-Tutorial/Relay-Interfacing.html"
2. How do you choose what kind of pull up resistor to use? would a 10k resistor be fine instead of a 4.7k?
First, be clear about the specifications of the relay. You are kind of mixing its input and output specifications, which are used for very different calculations.
Radio Shack said:
Maximum switching power of 10 (watt/VA)
Maximum switching voltage of 60 VDC, 120VAC
Maximum initial contact resistance of 150m ohms (150 milliOhms)
Those are output specifications, having to do with the output contacts and their ratings of max current and max initial resistance. What you need in order to figure out how to drive the input coil, is the input coil resistance, or the current that the coil draws when 5V is placed across it. Neither of these specifications seem to be listed on these Radio Shack pages (not unusual for Radio Shack, unfortunately).
So I went to www.digikey.com to look for a similar relay, did a search on 5V reed relay, and started applying filters to the results. This is one that's 0.5A rated for the output coil, but for a little higher voltage than the Radio Shack one you listed:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=306-1107-ND
This relay's coil current is rated at 21.7mA, which it sounds like your device could drive directly, except for the 3V output part. So use the 3V output to drive an NPN transistor directly as shown in the page I linked to, and don't worry about the pullup resistor shown on the base of the NPN -- you don't need it if the drive signal is rail-to-rail 3V. You should put something like a 1kOhm resistor in series between your logic drive output and the NPN base input, to limit the base current.
You should spend a little time looking at similar relays, with better datasheets, to see what the range of coil currents look like for the various output characteristics. I don't know what you are using the relay for, so I don't know the best relay to recommend out of the selection at Digikey.
Thanks, I have it working now. I used a 1k Ohm resistor between the logic drive input and the base of the NPN transistor as suggested and it works. I'm just wondering how you're supposed to choose what resistor to use on the base?(How did you know to use a 1k Ohm instead of the 4.7k Ohm.
On the back of the box of transistors i grabbed it has a section of Maximum rating:
Vce: 30V
Ic: 800mA
Power dissipation: 1.8W
How do you relate these ratings with the 1k Ohm resistor?
Vce: 30V
Ic: 800mA
The base drive resistor (between the drive source and the base of the transistor) is sized to deliver enough base current to generate the required collector current in the transistor. Look up the "Beta" specification for the transistor -- that is the current gain Ic/Ib. If you have a Beta = 100 in the range of collector current that you need (Beta varies with Ic), then you need to be sure that you supply at least 1/100 of Ic as Ib when you want the transistor on. The base voltage for a grounded emitter NPN transistor is going to be about 0.6V to 0.7V when the transistor is on, and you are driving with 3V, so that gives you about 2.3V/1kOhm = 2.3mA, which supports up to 0.23A of Ic if the Beta is 100 for that transistor for Ic=0.23A (which I don't know for sure, since I didn't look up the transistor datasheet, but you should check this).
You check the power dissipation of the transistor by finding out its saturation voltage (check the datasheet) for this Ic, and then multiplying Vsat*Ic to get the power dissipation when the transistor is on (and in saturation). Makes sense?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
