How do you decide whether to use cosine or sine when calculating torque?
  • Thread starter Thread starter Tybstar
    Torque
When calculating torque, the choice between using cosine or sine depends on the orientation of the force and the lever arm. The torque equation is τ = Frsin(θ), where θ is the angle between the force vector and the position vector. For this problem, the force of gravity (mg) acts downward, and the lever arm is the distance from the pivot point to the point of force application. The perpendicular component of the force to the lever arm is mgcos(θ), while the perpendicular component of the lever arm to the force is Lcos(θ). Understanding the geometry of the situation helps determine which angle to use for accurate torque calculations.
Tybstar
I'm working through a problem:
"A particle of mass m is attached to a rod of negligible mass and length L. The rod is attached to the ground at point O. If the rod makes an angle \Theta with the horizontal as it falls, calculate the torque about point O.
Here's a rough sketch of the diagram:
My book says that the equation for torque is \tau=Frsin\theta where \theta is the angle between the force and position vector.
The answer for this is Lmg cos\theta, but I don't understand why it's cosine. The book answer says to solve it in one of two ways: by multiplying the perpendicular component of the force vector to the lever arm, or by multiplying the perpendicular component of the lever arm to the force (indicating these two methods are equivilent).
How do you decide whether to use cosine or sine?
Thanks!
You basically do it like they said in your book
If you do it like this, the component of the force perpendicular to the lever arm is mgcosθ. Do you understand how the force is split into this components and a sine component parallel to the arm?
The length of the lever arm perpendicular to the downward force mg is Lcosθ. This one should be easier to see.
Thanks for the help.
I do understand how the force is split with cosine and sine. My problem is figuring out which angle to use. Is it similar to assigning force vectors in an inclined plane diagram?
Thanks!
This equation sums it up pretty nicely. Where's the force vector (hint: the force is gravity)? Where's the position vector (hint: it's the vector from the pivot to the object)? Which angle is the angle between them?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
