How Does Air Resistance Affect the Speed of a Falling Pine Cone?
A 0.25 kg pine cone falling from 20 m would hit the ground at a theoretical speed of 14 m/s if air resistance is ignored, calculated using energy conservation principles. However, if the actual impact speed is 9.0 m/s, the average force of air resistance can be determined by comparing the kinetic energy it should have had versus what it actually has upon impact. The kinetic energy at impact can be calculated using the formula KE = 1/2 mv^2, while the potential energy is given by PE = mgh. The difference in energy indicates how much energy was lost to air resistance, which can then be used to find the average force using the equation Force = Energy / distance. Understanding that the mass does not affect the speed of free fall is crucial, as all potential energy converts to kinetic energy in the absence of air resistance.
get_rekd
A 0.25 kg pine cone falls from a branch 20 m above the ground.
A) With what speed would it hit the ground if air resistance could be ignored?
m= 0.25 kg
g= 9.8 m/s^2
d= 20 m
Ep= (0.25kg)(9.8m/s^2)(20m)
= 49 J
Ek= 1/2mv^2
49J = 1/2(0.25kg)(v^2)
2(49 J = (0.5kg)(0.5 v^2))
98 J = (0.5 kg)(0.5 v^2)
-0.5 -0.5
97.5 J = 0.5 v^2
0.5 0.5
v^2 = 195
v = 14 m/s
can someone check this for me please?
part b)
If the pine cone actually hits the ground with a speed of 9.0 m/s, what was the average force of air resistance on it?
I am not sure how to solve this problem?
Can someone please walk me through it?
For part a I get, using mgh=1/2mv^2, v=sqrt(2gh) = sqrt(2*20*9.8) = 19.8m/s
For part B. Work out the KE it hits the ground with, the KE it should have had, and so how much E is lost ot friction.
Then from Energy = force * distance, you can work out an average force.
is mgh=1/2mv^2=sqrt(2*20*9.8) a shortcut or is that the way that I should setup the problem from the start? What is the 2 for in the equation. I understand that 20 = h and 9.8 = g
anyone?
Kinetic energy = 1/2 m v^2.
Potential energy = m g h
If the object falls from rest (no initial velocity) and no energy is lost to friction, then the easiest way of working out the speed is to assume all the potential energy is converted to kinetic energy. Note that the mass of the object cancels out - the speed something falls at doesn't depend on it's mass.
