How Does Kinematics Influence Base Running Techniques in Baseball?
This discussion focuses on the investigation of kinematics in relation to base running techniques in baseball, specifically comparing the effectiveness of rounding the bases versus running straight to each base. Key variables for evaluation include instantaneous velocity, average velocity, and time taken to round the bases. The discussion emphasizes the importance of measuring the time and distance required for a runner to decelerate and accelerate at each base, and suggests creating speed versus time graphs to analyze the results definitively.
  • Understanding of kinematic equations, specifically v=s/t, F=ma, and p=mv.
  • Familiarity with concepts of instantaneous and average velocity.
  • Knowledge of basic experimental design and data collection methods.
  • Ability to create and interpret speed versus time graphs.
  • Research methods for measuring instantaneous and average velocity in athletic performance.
  • Explore techniques for timing and recording data during base running experiments.
  • Learn about the physics of acceleration and deceleration in sports contexts.
  • Investigate the use of motion analysis software for detailed kinematic studies.
This discussion is beneficial for sports scientists, baseball coaches, athletic trainers, and students conducting research on biomechanics and performance optimization in baseball.
A2Airwaves
I'm currently working on doing an investigation on the relationship between kinematics and base running techniques in baseball. I'm trying to find out if "rounding the bases" is better than running straight to each base and turning, but I haven't found how I should preform the experiment and using what variables I should evaluate the technique. Can someone give me advice on it? How can I measure the velocities of the runner running bases?
v=s/t
F=ma
p=mv
I'm currently thinking of using:
- instantaneous velocity
- average velocity
- time taken to round bases
to evaluate the techniques, but I'm really lost... please help thank you!
Assume that the runner turns 90 degrees at each base. That means he has to stop his forward motion and immediately accelerate 90 degrees to the left at each base.
Compare that to a circular run (on a circle that touches on all bases and home plate) at constant speed.
Try using some reasonable assumptions about how long it takes to slow down and get back up to speed (how much distance is needed to slow to a stop - how much distance is required to accelerate to top speed)?. You might have to time somebody running some bases by starting/stopping at each base.
Do a speed v. time graph for each. Then work out the total time for each.
AM
Thank you for the help, it helped a lot! I hope I will get good results from the investigation.
  • · Replies 16 ·
