How does static friction do work?
The discussion revolves around the concept of static friction and its ability to do work on an object. Participants are examining the conditions under which static friction may or may not perform work, particularly in different reference frames.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the premise that static friction cannot do work, with some suggesting counterexamples involving moving boxes. Questions arise regarding the role of reference frames in determining whether work is done by static friction.
The discussion is active, with various interpretations being explored regarding the relationship between static friction and work. Some participants have provided examples and counterexamples, while others are questioning the implications of reference frames on the concept of work.
There is an ongoing debate about the definitions and assumptions related to work and static friction, particularly in relation to different inertial and non-inertial frames of reference.
c_programmer
Static friction can never do work on an object.
a. True
b. False
The answer is False, indicating that static friction can do work.
W=fd, when d=0 w=0 regardless of the force.
How does this work? Or is the online homework wrong.
I think I might have an answer. Imagine a box on top of another, there is a large static friction coefficient between the two boxes and none on the floor. When the bottom box is moved the static friction will cause the box to move, thus doing work. Is this correct?
Yes, I thought of the same counter example. However in the reference frame of the contact surface, static friction can't do work.
Work always depends on the reference frame.
Chet
Chet
Why does work depend of the reference frame? If we do work isn't it the change of kinetic energy equal for all observers? The velocity vectors may change, of course, but the difference shouldn't for two inertial frames. Is it different for non-inertial frames?
Yes. You hit the nail on the head. Consider the case of a box on a conveyor belt, and the speed of the belt is increasing with time. So the frictional force is causing the box to accelerate, and the box is gaining kinetic energy. Now consider this same situation from the perspective of an accelerating frame of reference that is moving with the box. From this frame of reference, the frictional force is not doing any work, and the box is not accelerating. The frictional force is being balanced by the apparent horizontal body force acting on the box (associated with the acceleration).
Chet
  • · Replies 90 ·
  • · Replies 42 ·
