How Does Thermal Expansion Affect Stress in a Bar?
Thermal expansion in a bar can be calculated using the formula (1 + alpha delta T) to determine the change in length due to temperature variations. To find the stress when the bar is constrained, the relevant equation is S = e * E, where S is stress, e is strain, and E is Young's Modulus. The user needs to calculate the force required to compress the bar back to its original length to determine if it can support a load of 40 tonnes. Understanding the relationship between thermal expansion and stress is crucial for solving this problem. Proper application of these equations will lead to the desired solution.
heloo
Hi, I have been asked to determine the stress in a bar which has a diameter of 50mm when the temperature changes from 20 C to 50C. That's the first part.
Secondly, I need to then answer whether or not the stress will be sufficient enough to raise a constraining load of 40 tonnes.
Young's Modulus is 70Gpa.
I think i need to use (1+alpha delta T), to work out the change in length. But that's as far as I've got.
Can anyone give me a pointer in the right direction as i totally confused myself.
Thanks
Yes
Unsure of what equations are relevant
None
OK, you have the equation to determine the change in length were it not constrained. So how much force does it take to compress it back to its original length? Do you know what equations to use?
I am unsure of what equations to use, i assume i need to work out the thermal expansion but i don't know how to calculate how much force is needed to force it back to its original length.
You should have seen the following equation by now in your studies:
S = e * E
where S is stress, e is strain, and E is Young's Modulus. Given the definition of stress as force per unit area, you can solve it from this point onward.
Thread 'PLL - How to find all the gains of a PI corrector and fix Ki ? MATLAB'
Hello everyone, it's not really for my homework (because I'm not at school anymore) but I'm new and I don't know how to start a new forum. I've never done automatic before and I need help. I have a 2nd ordre PLL on MATLAB, with an NCO and a PI corrector; the PLL works via the Mid/End algorithm (that's part is ok). I need to find the link between the theoretical formulas and their values in the code to find the value of the gain Ki, and possibly that of Kp if it's not correct. Unfortunately...
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
