How Does Torque Affect the Movement of Unequal Weights on a Wheel?
  • Thread starter Thread starter botagar
    Wheel
Torque affects the movement of unequal weights on a wheel by determining the force applied to the system. In the first scenario with two 16-tonne weights, a motor providing 40Nm of torque would produce a force of 40N, leading to a specific acceleration based on the total weight. The second scenario, involving a 16-tonne and a 12-tonne weight, requires calculating the necessary torque to achieve a desired upward speed of 2m/s for the heavier weight. The calculations depend on the radius of the wheel, which influences the relationship between torque, force, and acceleration. Understanding these principles is crucial for applications like elevator systems in vertical shaft mines.
botagar
I tried a google search on the question I am about to ask but i get everything except for what i want... :(
I have 2 situations:
i have 2 16Tonne weights connected to each other via cable, and then hung around a wheel so that the 2 weights hang side by side with no movement. If i then connect a motor which produces 40Nm of Torque to the wheel (assume no loss in any of the mechanical compartments), how fast would the weight accelerate and what top speed would they have (if that's even possible to calculate). (yes, one weight would go down and the other go up).
Situation 2:
similar to the one above except now the weights ARE NOT equal, one is 16T and the other 12T. What torque motor would i need to get the 16T weight moving upwards at 2m/s ?
To be honest, i thought i could do this when i was asked to do something similar, but when i sat down to do it, i was lost. It's been a while since i have done any physics and as i said, google gave me nothing useful from what i could tell.
Are these questions even answerable?
Any help is greatly appreciated!
These calcs are doable?
Not without the radius of the wheel.
torque = force * radius
weight = mass * 9.8 m/s²
For your second question the answer has units of power, not torque.
power = force * velocity
sorry yes, radius of wheel is 1m, (2m diameter).
These both are hypothetical but potentially real questions with regards to vertical shaft mines. An elevator system if you like.
So, in the case of
1), 40 = F * 1 = 40N --> so it takes 40N of force to move it 1m/s ?
as for 2), if i can get 1), 2 is not needed.
for case 1)
I think an acceleration of even 1m/s should be sufficient
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
