How Does Varignon's Theorem Simplify Calculating Moments in Statics?
  • Thread starter Thread starter physicsnewblol
    Statics Theorem
The discussion revolves around the application of Varignon's Theorem in calculating moments in statics. Participants explore how to find the moment of a force given specific parameters, including the force's magnitude, coordinates, and pivot point.
  • Technical explanation, Homework-related, Mathematical reasoning
  • One participant asks how to find the moment of a force using Varignon's Theorem, specifying the parameters involved.
  • Another participant explains that Varignon's Theorem states the moment of a force about a pivot point equals the sum of the moments of its components about that point, suggesting that an attempt at a solution is needed for further assistance.
  • A later reply indicates that the original poster was correct in their approach but claims the book provided an incorrect answer, detailing a method involving the cross product of vectors to find the moment.
  • This participant also notes that while the method of M = rF sin theta yields the correct answer, it does not apply Varignon's Theorem, which could simplify the solution.
Participants do not reach a consensus on the application of Varignon's Theorem, as there are differing views on the methods used to calculate moments and the correctness of the book's answer.
The discussion highlights potential confusion regarding the application of Varignon's Theorem versus other methods for calculating moments, as well as discrepancies in textbook answers.
physicsnewblol
In general, how would you find the moment of a force given:
  • the magnitude of the force
  • two coordinates that form a line that contains the force vector
  • the pivot point
  • the pivot point
I hope you looked up Varignon's theorem as it applies to moments. It essentially states that the moment of a force about a pivot point is equal to the sum of the moments of the components of that force about the point. You must show an attempt at your solution for further assistance.
Nevermind, I was doing the problem correctly but the book listed an incorrect answer. To answer my own question, you simply choose one of the points as the application point of the force. You then proceed to find the distance vector which is essentially the application point written in vector form. Take this vector and find the cross product with the vector representation of the force.
The problem is number 31 in Engineering Mechanics: Statics, by J. L. Meriam and L. G. Kraige. The correct answer is 518 N*m
That method of M = rF sin theta will yield the correct answer, but that is not applying Varignon's theorem, which often simplifies the solution.
