How many Watts do I need to heat this pipe?
  • Thread starter Thread starter steves1080
    Heat Pipe Watts
To prevent freezing in a 4-inch diameter, 1-foot long section of carbon steel pipe, an immersion heater is needed, but accurate wattage calculations are essential. The heat transfer equation provided can help estimate the required power, factoring in thermal conductivity and temperature differences. However, the initial calculations yielded an unexpectedly high wattage, suggesting potential errors in the approach, particularly in logarithmic and area calculations. Adjustments to these calculations indicate that a significant wattage, around 22 kW, may be necessary due to a large temperature change and high thermal conductivity. Accurate calculations are crucial for effective heating without oversizing the heating element.
steves1080
Reference attached image.
In this simple system, I have a large reservoir of water that feeds a small section of 4" dia. pipe. There is about 1 ft of length until there is a gate valve to isolate the flow. When not flowing water, this 1-ft x 4-in section is at risk of freezing when temperatures are low enough. What I am looking to is basically add an immersion heater to prevent freezing, but I need to know how much power I need. Are there any quick heat transfer calc I can do to estimate this?
Thanks a ton-
It's carbon steel, so thermal conductivity is like 16 or so
Hi,
The following equation might help.
q = 2 π k (ti - to) / ln(ro / ri) (1)
where
q = heat transferred per unit time per unit length of cylinder or pipe (W/m, Btu/hr ft)
k = thermal conductivity of the material (W/m.K or W/m oC, Btu/(hr oF ft2/ft))
to = temperature outside pipe or cylinder (K or oC, oF)
ti = temperature inside pipe or cylinder (K or oC, oF)
ln = the natural logarithm
ro = cylinder or pipe outside radius (m, ft)
ri = cylinder or pipe inside radius(m, ft)
If you know what the coldest temperature that the water will be the temperature that you wish to keep the pipe at, you can find the heat transferred per length then multiply that by the length of your pipe (4ft). This will give you a watt value to heat the pipe.
Yea, I know I shouldn't be reinventing the wheel. But I'm very old fashioned and like to make sure I run my own numbers. The problem, acc0untnam3, with that approach (albeit the seemingly correct one), is that I am getting a massively high wattage of heat loss. Like WAY too high. But I am not seeing an issue with my numbers, so it must be the approach I am taking. See attached for my calculation. Any help would be extremely appreciated.
You forgot the natural logarithm..
ln(ro/ri) = 0.110311, you're using the thickness 0.005969 m...
The area is also wrong, you should calculate 2*PI()*L. Still Q is around 22kW.
I think Q is high because you have a 20ºC change in 5mm, and your thermal conductivity is quite high,,
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
