How Much Light Intensity Is Needed to Suspend a Sheet of Paper?
To suspend an 8.5 by 11 inch sheet of black paper weighing 1.0 g in a vertical beam of light, a light intensity of 4.87x10^7 W/m^2 is calculated. The force acting on the paper is determined to be 9.8x10^-3 N, and the corrected area of the paper is 6.03x10^-2 m^2. There is a concern about the potential for the paper to burn due to the high intensity of light required. The calculations and assumptions made in the solution are being double-checked for accuracy. The discussion emphasizes the need for precise measurements and considerations in the experiment.
lunus
For a science project, you would like to horizontally suspend an 8.5 by 11 inch sheet of black paper in a vertical beam of light whose dimensions exactly match the paper.
If the mass of the sheet is 1.0 g, what light intensity will you need?
Equation I used: F = IA/c
F = 9.8x10^-3 N
A = 6.03 m^2
c = 3.00x10^8 m/s^2
I = Fc/A
I = 4.87x10^7 W/m^2
This is my attempt at the solution. I think its correct but I would like to double check. I would appreciate any help. thank you
F = 9.8x10^-3 N
A = 6.03 m^2
c = 3.00x10^8 m/s^2
I = Fc/A
I = 4.87x10^7 W/m^2
What's the area of that sheet of paper?
A = 6.03x10^-2 m^2
The area i had above was a typo
lunus said:
A = 6.03x10^-2 m^2
OK, no problem then.
Except that maybe it will burn up?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
