How to analyse an atomic bomb?
In summary, Sarah, you need to do more reading and research on nuclear physics before you can attempt to answer this question.
Sarah Madsen
< Mentor Note -- thread moved to HH from the technical physics forums, so no HH Template is shown >
Hello mates.
I was wandering how to analyze an atomic bomb, when the only information given, is that the bomb contains 5,6 kg plutonium, and is the same model as fat man.
Do you have any suggestions about formulas, and other things that can be analyzed through physics?
i was thinking about measuring the blast radius, and how long it takes for the exposed area to be radiation free, but can't find the proper formula and information.
Thanks in advance, English is not my main language, sorry for possible errors :)
Sarah Madsen said:
Hello mates.
Welcome to the PF, Sarah.
Is this question for schoolwork? What reading and research have you been doing so far? If you can post links to your reading and ask specific questions about things you aren't understanding in that reading, that would be help...
It´s a question for a school project. i got the basics in nuclear physics covered and knowledge about fission. It´s more the question about what to analyse? I thought about the blast radius and the energy that´s released, but is there other things I can calculate?
With only the amount of plutonium given you cannot do much, because you don't know how much of that plutonium will actually fission. You can try to find actual nuclear weapons of similar size to get an estimate. Once you have the yield, you can study effects of the explosion - blast radius, fallout, potential effects on a city, whatever.
It says that the nuclear bomb is like the fat man bomb, but will this help in finding out how much of the plutonium that fission?
It is known (approximately) how much of the plutonium in Fat Man fissioned.
So I need to find the energy released of a 6,4 kg plutonium, based on fat man.
First I tried to make an example with the fat man. so the fat man had Approx 1.176 Kilograms of plutonium converted to energy. Which means E=m*c^2 1
1,176*300000000^2=1,0584*10^17
which is 2457934990.4398 Kilotons, and fat man was about 20 kilotons.
What am i doing wrong?
Might be a stupid question, but i really don´t understand nuclear physics :(
I think i need to find something like this, but how to convert 6,4 kg plutonium to this?
That's not what happens in nuclear fission.
The plutonium is converted to fission products. Only a small fraction of its mass is released.
Perhaps if you knew the ... nuclear weapon yield ... of Fat Man you could scale the yield of the weapon you are analyzing to that of the Fat Man. You could of course also try to establish a theoretical upper limit of the yield as your last post indicates you are looking into, but then you still need to know how much of that maximum eventually end up as effective yield.
I tried, but as you can see, the result is too high compared to the original amount of megatons.
I think I am missing the basics, but still looking for the answer.
I tried to calculate the Q of plutonium 239.
Q=8,4022*10^-13 J
But i don't know what to do next.
so i found this formula.
Ekin after=Q+Ekin before.
Is this any good?
Perhaps you can try search for information on "nuclear weapon yield" and "plutonuim-239" and use that to get an overview of the processes involved? Perhaps you can even find an almost direct reference to how much energy pr kg that eventually is released during fission of Pu-239 and use that to get an upper limit of the yield. I still recommend that you look for the yield of Fat Man and compare this to how much Pu-239 it had, and then use this for the amount of Pu-239 you are supposed to analyse.
Q=8,4022*10^-13 J
That is the value for alpha decay. Again: fission is something different.
You can look up how much energy a plutonium atom releases in fission on average. You cannot calculate that value, you have to look it up (or directly use values for yields from elsewhere). Afterwards: How many plutonium atoms are there in 1 kg of plutonium?
Where did you get that number?
Have you looked under "Specifications" on the Wikipedia page?
https://en.wikipedia.org/wiki/Fat_Man
And, just to spell it out, please note that Fat Man only achieved a fraction of the theoretical maximum yield for Pu-239 fission, which means you cannot just calculate the theoretical maximum yield and call that the effective yield of a similar Fat Man weapon. The exact fraction is not difficult to calculate once you have found the basic "performance numbers" mentioned in this thread.
So i tried something else, but can i use it?
I dertirmined that it was plutinium239.
Where 6,4*10^3 is the mass.
Where 239,052158 is the mass/Unit before fission
and 239,046527 is the mass/Unit after.
Fission is not an alpha decay. You won't get any correct answer if you keep ignoring this fundamental error.
Thanks for the help, i found the solution ;)
Well according to Wikipedia the filling weight of the Fat Man was 6.4 kg
The yield of that model was 21.0 kt
I assume that for 5.6 kg of filling you would get 87.5% of that or about 18.375 kt
I maybe wrong as I am by no means versed in nuclear physics and the yield may not be linear
Are you going to tell us what it is or are you going to keep us in suspense?
Related to How to analyse an atomic bomb?
1. How does an atomic bomb work?
An atomic bomb works by using a process called nuclear fission, which involves splitting the nucleus of an atom to release large amounts of energy. This energy is then harnessed and amplified to create a powerful explosion.
2. What is the difference between an atomic bomb and a nuclear bomb?
An atomic bomb and a nuclear bomb are often used interchangeably, but technically an atomic bomb refers to a weapon that uses fission to release energy, while a nuclear bomb can also refer to a weapon that uses fusion or a combination of both fission and fusion to create an explosion.
3. How do scientists analyse the effects of an atomic bomb?
Scientists use a variety of methods to analyse the effects of an atomic bomb, including measuring the size and intensity of the explosion, studying the radioactive fallout, and examining the physical and environmental damage caused by the blast.
4. What are the potential consequences of an atomic bomb explosion?
The consequences of an atomic bomb explosion can be devastating, including destruction of buildings and infrastructure, loss of life, and long-term health effects due to radiation exposure. The environmental impact can also be significant, with contamination of land, water, and air.
5. How do scientists ensure the safety of the surrounding area when analysing an atomic bomb?
Scientists take precautions to ensure the surrounding area is safe when analysing an atomic bomb, such as wearing protective gear and using remote-controlled equipment. They also carefully monitor radiation levels and follow safety protocols to minimize any potential risks.
  • High Energy, Nuclear, Particle Physics
