How to find displacement of 400m track
To find the displacement of a runner completing 6.5 laps around a 400m track, it's essential to consider the starting and ending points. Displacement is defined as the shortest distance from the start to the finish, which can be less than the total distance run if the path is curved. The correct displacement for this scenario is 160m, as indicated by the provided answer. The realization of a diagram accompanying the question clarifies the displacement measurement. Understanding the geometry of the track is crucial for accurately determining displacement.
Rbraind
I know this is basic but I'm stumped
a runner runs 6.5 laps around a 400m track, what's the displacement. I thought it would be 200m but the answer provided says 160m and I just can't work out how to get to this answer
You might need some more details about the shape of the track and the runner's starting point.
Displacement will equal the length of the shortest line possible drawn from the starting point to the ending point. As you can see, if the track has any curvature at all during that half of a lap, the displacement will be less than 200 m.
Thanks people for your help. However I'm an idiot! Just realized there was a diagram with the question and the displacement marked in...
19K
