How fast will the electron be travelling?
  • Thread starter Thread starter Brooke22
    Electron
The discussion centers on calculating the speed of an electron using the classical kinetic energy formula Ek = ½ MV^2. The calculations suggest that a larger voltage could result in speeds exceeding the speed of light, which is incorrect. This discrepancy arises from not accounting for relativistic effects, as classical mechanics fails at high speeds. It's emphasized that the relativistic theory must be applied for accurate results at such velocities. The conversation highlights the importance of verifying calculations and understanding the limits of classical physics.
Brooke22
Ek = ½ MV^2
V = 2Ek/M
V = √2Ek/M
= √ 2 x 1.6x10^-19/9.1 x 10^-31
This number is too high since it implies that a larger voltage (say 10) would make the electron travel faster than light. The reason is?
You might want to give at least SOME info about the problem and what you're trying to do.
Were you solving E=1/2mv^2 for v?
By the way. You're using the classical formula 1/2mv^2 for the kinetic energy. Ofcourse you can get velocities faster than light if you don't take relativity into account.
That's right. When doing with high speed, you have to apply the relative theory.[/color]
Ek = ½ MV^2
V = 2Ek/M
V = √2Ek/M
That doesn't mean your answer might not be correct. I've found that kind of mistake in any number of Introductory level texts. Check with your instructor.
-Dan
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
