Investigating Strength of Hydrogen Bonds: Cyclohexane/Ethanol Experiment
The discussion revolves around an experiment investigating the strength of hydrogen bonds in a mixture of cyclohexane and ethanol. The key observation is a temperature decrease upon mixing, attributed to the breaking of hydrogen bonds between ethanol molecules. Cyclohexane, being less electronegative, does not significantly interact with the hydrogen of ethanol, leading to a dilution effect. The presence of cyclohexane disrupts the hydrogen bonding network among ethanol molecules, resulting in a negative deviation from Raoult's law. This indicates that the intermolecular forces between ethanol and cyclohexane are insufficient to maintain the original hydrogen bonding strength in ethanol. The conversation also touches on the distinction between intramolecular and intermolecular hydrogen bonding, highlighting the impact of cyclohexane on the ethanol's hydrogen bonding capabilities.
hydrogène
i'm writing a lab report of an experiment investigating strenth of hydrogen bond. An excess of cyclohexane was mixed with ethanol and there's a decrease in temperature of the mixture. I was told that upon the addition of cyclohexane, the H bonds between ethanol molecules were broken and I don't know why. C of cyclohexane are probably not electronegative enough to give the H directly bonded to them a delta +ve charge to attract lone pair electron of O from ethanol. Van der Waal's forces between molecules of ethanol and cyclohexane are not strong enough to overcome the H bonds. Can anyone explain to me what had cyclohexane done on the ethanol molecules?? thanks a lot~
Chemistry news on Phys.org
I would bet on dilution.
Chemical calculators for labs and education
BATE - pH calculations, titration curves, hydrolisis
Tis an example of negative deviation from Raoult's law. Cyclohexane is interposed between the ethanol molecules reducing the degree of hydrogen bonding...note the difference between intramolecular hydrogen bonding and intermolecular hydrogen bonding.
I haven't learned this law. Can you say more about it??
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
