I don't agree with the solution manual of a mixed poisson problem
yungman
Solve mixed poisson's problem on disk given
\nabla^2 U= r sin \theta \hbox{ for } 0 <r< \frac{1}{2}
\nabla^2 U= 0 \hbox{ for } \frac{1}{2} < r < 1
With given boundary condition U(1,\theta)=0
2. Answer from the solution manual
U(r,\theta) = \sum_{m=0}^{\infty} \sum_{n=1}^{\infty}\phi_{mn}(r,\theta)
\phi_{mn}(r,\theta)= J_m(\lambda_{mn}r)[A_{mn}cos (m\theta) + B_{mn}sin (m \theta)]
Helmholtz \Rightarrow \nabla^2 \phi_{mn}(r,\theta)= -\lambda_{mn}\phi_{mn}(r,\theta)
\nabla^2 \sum_{m=0}^{\infty} \sum_{n=1}^{\infty}\phi_{mn}(r,\theta) = \sum_{m=0}^{\infty} \sum_{n=1}^{\infty}-\lambda_{mn}J_m(\lambda_{mn}r)[A_{mn}cos (m\theta) + B_{mn}sin (m\theta)] = r sin(\theta)
Using Fourier series expansion:
\Rightarrow \sum_{n=1}^{\infty} -\alpha^2_{1n} B_{1n} sin(\theta) J_1(\alpha_{1n}) = r sin(\theta)
\Rightarrow -sin(\theta) \int_0^{\frac{1}{2}} \alpha^2_{1n} B_{1n} J^2_{1n}(\alpha_{1n}r)rdr = \int_0^{\frac{1}{2}}sin(\theta) r^2 J_1(\alpha_{1n}r)dr
-\alpha^2_{1n} B_{1n} = \frac{J_2(\frac{\alpha_{1n}}{2}}{2\alpha_{1n}J^2_2(\alpha_{1n})}
3. My questions:
Why is this treated as only a poisson problem only for 0<r<1/2 and ignor 1/2<r<1.
I thought this is a two parts problem where it is a poisson problem for 0<r<1/2 and Laplace problem for 1/2<r<1.
Anyone please?
I know this is very similar to Fourier series expansion like:
f(x) = h(x) for 0<x<1
f(x) = 0 for 1<x<2
0<x<2
Where the Fourier series expansion only integrate from x=0 to x=1 only and totally ignor the portion of x=1 to x=2.
I never see the prove, this only show up in the work problems. Can anyone show me the prove of this.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
