Ideal Gas Law Chang ein VolumeProblem
The discussion focuses on calculating the pressure required to prevent the expansion of water when its temperature is increased from 20°C to 30°C, utilizing the volume expansion coefficient (β = 2.57 × 10-4K-1) and isothermal compressibility (κ = 4.52 × 10-10Pa-1). The user correctly identifies that the change in volume can be expressed as ΔV/V0 = βΔT. The final conclusion is that the pressure change can be calculated using the formula ΔP = (β/κ)ΔT, establishing a direct relationship between temperature change and pressure change while holding volume constant.
  • Understanding of thermodynamic concepts such as volume expansion coefficient and isothermal compressibility.
  • Familiarity with partial derivatives in the context of thermodynamic equations.
  • Knowledge of the Ideal Gas Law and its applications.
  • Basic proficiency in calculus, particularly in differentiation.
  • Research the implications of the Ideal Gas Law on real gases under varying temperature and pressure conditions.
  • Explore the derivation and applications of the volume expansion coefficient (β) in different fluids.
  • Study the relationship between isothermal compressibility (κ) and pressure changes in liquids.
  • Learn about the mathematical treatment of partial derivatives in thermodynamics.
Students and professionals in thermodynamics, chemical engineering, and physical chemistry, particularly those dealing with fluid properties and phase changes under varying conditions.
Elzair
I am having a little trouble on this problem:
For Water at [tex]25^{\circ}C[/tex], (Volume Expansion Coefficient) [tex]\beta = 2.57 * 10^{-4}K^{-1}[/tex] and (Isothermal Compressibility) [tex]\kappa = 4.52*10^{-10}Pa^{-1}[/tex]. Suppose you increase the temperature of some water from [tex]20^{\circ}C[/tex] to [tex]30^{\circ}C[/tex]. How much Pressure must you apply to prevent it from expanding?
Can I treat this as an Isobaric expansion and an Isothermal compression?
I think I found the change in Volume like this: [tex]\frac{\Delta V}{V_{0}}=\beta\Delta T[/tex]
How do I find the Pressure?
well, I suppose you wish to find ΔP/ΔT, holding V constant,
so, consider P as a function of T and V, we know the partial derivatives relating to V, but not T. So consider, V=const (we are holding V constant), or V(T,P)=const, then
[tex]dV=\left(\frac{\partial V}{\partial T}\right)_P dT + \left(\frac{\partial V}{\partial P}\right)_T dP=0[/tex]
so that:
[tex]\left(\frac{\partial P}{\partial T}\right)_V=-\frac{\left(\partial V / \partial T\right)_P}{\left(\partial V/\partial P\right)_T}[/tex]
now, look at the definition of [itex]\beta[/itex] and [itex]\kappa[/itex], what are they (hint: they are related to partial derivatives of V)?
Thanks!
Thanks, I think I got it. I will now post the answer here for others.
[tex]\frac{dV}{dT} = \frac{\beta}{\kappa}[/tex]
therefore [tex]\Delta P = \frac{\beta}{\kappa}\Delta T[/tex]
P.S. Does the Tex function on this forum feature a way to represent the therefore symbol (i.e. a triangle of three dots)?
  • · Replies 33 ·
10K
