Calculating Work Done by a Spring
To calculate the work done by a spring when a 2.0 kg mass is hung from it, the spring constant (k) is determined using the formula k = F/d, where F is the weight of the mass (19.6 N) and d is the extension (0.06 m), yielding k = 326.667 N/m. The work done by the spring is calculated using W = 0.5(k)(xi)^2 - 0.5(k)(xf)^2, with xi and xf representing the distances from the equilibrium position. The resulting work done by the spring is -1.04 J, indicating that the spring is doing negative work as it opposes the external force. The negative sign is expected since the spring force acts in the opposite direction to the displacement.
Le_Anthony
An ideal spring is hung vertically from the ceiling. When a 2.0 kg mass hangs from it at rest, the spring is extended 0.06 meters from its relaxed state. An upward external force is then applied to the block to move it upward a distance of 0.16 meters. While the block is being raised by the force, the work done by the spring is:
Force from a spring= -kd
Work due to a spring= .5(k)(xi)^2-.5(k)(xf)^2
I believe to find the magnitude of the spring constant i rearrange F= -kd to become k=F/d (i read that we can neglect the negative in this case? correct me if I am wrong)
so F=mg=(2.0kg)(9.8m/s^2)=19.6N
19.6N/.06m=326.667N/m=k
Finally, W=.5(326.667N/m)(.06m)^2 - .5(326.667N/m)(.10m)^2= -1.04J
Did i find the spring constant correctly? I feel like using mg/d was wrong.
Also, when i use the work done by spring equation, is xi and xf the distance away from equilibrium?
the k value is correct.
regarding work done by the spring -pl. check whether the choice of xi and xf is correct...
in the sector of extended portion the external force was supporting the wt. so what work was done by the spring -it came back to the relaxed state...i am just trying to think ...alongwith you
Likes Le_Anthony
Yes, that's ok. In fact, the force is always opposite to the displacement, so technically it should be k=-F/d.
That all looks correct. Are you surprised by the minus sign?
Likes Le_Anthony
