IEC 60529 Definition of "Finger Safe" for Cylinders
The discussion centers on the definition of "Finger Safe" as per IEC 60529, specifically regarding the IP2X rating, which indicates that objects larger than 12.5mm should not allow finger access to hazardous parts. There is a query about whether this means a cylinder must be greater than 12.5mm in diameter and if there are specific design requirements, such as radius or length. The application involves industrial robots with high-power welding contacts, where safety is paramount to prevent accidental contact. Users express difficulty in finding detailed specifications or drawings that clarify the IP2X requirements. The emphasis is on adhering to the IEC standard for legal protection against potential safety incidents.
DTM
"Finger Safe"
I'm searching for a precise definition of "Finger Safe" according to IEC 60529 which defines
IP2X as "finger safe" for diameters > 12.5mm. Does thes mean a cylinder of > 12.5mm dia. an not touch the contact? Or is there a radius on the end of the cylinder? How long is the cylinder? Anyone have link to a drawing that better defines this 12.5mm "finger"
Thanks
I remember way back when having to machine a "finger probe" and a "tool probe" to make UL happy. I searched and found that this place sells a variety of similar probes.
http://www.ergonomicsusa.com/
Thanks Mike. That site did have lots of finger probes but none of the specific IP rating I need to meet, IP2X from IEC 60529. Anyone else know of where I might find details of the IP2X finger?
Are you trying to make it finger safe for a one year-old?
I tried the Google search. Only found lots of products that say their "finger safe" or meet IP2X rating. Thanks for the link to the Amateur radio site, but no copy of IEC 60529 there either.
This application is for an industrial robot. The contacts are for high power welding. They shouldn't ever be powered up when the robot is not attached to the welder and the contacts are exposed, but just in case you don't want to accidently be able to touch it and most of our customers require the IP2X level of protection for safety. We have an approximately 6mm annulus gap, but it's not very deep. Anyone who tries can get at least the tip of their pinky in there. Now someone is going to say, how idiot proof does it need to be? The answer, as idiot proof as the IEC spec requires. That provides some legal protection from eventual lawsuits from said idiots.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
