How to Prove Thermal Efficiency for an Imaginary Ideal Gas Cycle?
jrklx250s
Given an imaginary ideal-gas cycle. Assuming constant heat capacities, show that the thermal efficiency is
η = 1 - γ[((V1/V2)-1)/((P3/P2)-1)]
Since i can't show you the cycle we are shown that
l Qh l = which is absolute value of the heat at high temperature = Cv(T3-T2)
l QL l = which is absolute value of the heat at low temperature = Cp(T1-T2)
Cp/Cv = γ
Ok so subing in these equations for thermal efficiency
which is
η = 1 - l QL l / l Qh l
we get...
η = 1 - γ(T1 - T2)/(T3 - T2)
η = 1 - γ((T1/T3) - 1)
This imaginary cycle only has a power stroke and we are assuming that its adiabatic...from this we concluded that
T1V1^(γ-1) = T3V2^(γ-1)
T1P2^((1-γ)/y)=T3P3^((1-γ)/y)
divide each equation we get
V1^(γ-1)/P2^((1-γ)/y) = V2^(γ-1)/P3^((1-γ)/y)
Now I am not sure how to rearrange from here to make T1/T3 = (V1/V2)/(P3/P2)
Any suggestions would be greatly appreciative.
Thanks!
Since no one has replied I'm assuming some are confused as to what I'm talking about so here is the ideal gas cycle that I need to calculate the thermal efficiency from.
Here is the link to the picture of the cycle
http://imageshack.us/photo/my-images/411/img1048u.jpg/
Hi jrklx250s! :smile:
Did you already try to apply the ideal gas law PV=RT?
Hi Serena,
Yes I believe so when i calculated the adiabatic processes for the power stroke... which i concluded that they were
And Since I need to make T1/T3 = (V1/V2)/(P3/P2)
This means that T1 = (V1*P2)
and T3 = (V2*P3)
not sure how to conclude these from the two equations above. And I know its a simple alegbraic rearrangement that I am missing here.
Careful. Let's start with (V1/V2)/(P3/P2).
With some fraction manipulations this is equal to (P2*V1) / (P3*V2).
Looking at the diagram you posted I can see that P1=P2 and that V1=V3.
Furthermore you have that for instance P1*V1 = R*T1.
Perhaps you can use that?
Haha wow...thank you serena I was making this so much more complicated than it was.
Yea of course you can just conclude that since
P1=P2
V2=V3
so therefore...
P1V1=nRT1
P3V3=nRT3
P2V1=nRT1
P3V2=nRT3
solving for both T's
T1=P2V1/nR
T3=P3V2/nR
sub this in my previous equation and we get...
η= 1 - ((V1/V2)-1)/((P3/P2)-1)
Thank you.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
