Calculating Acceleration and Tension on an Inclined Plane with Friction
PIn summary, the conversation was about finding the magnitude of acceleration and tension of masses in a figure with two blocks, a 30 degree incline, and a coefficient of kinetic friction. The equations (1) and (2) were used to solve for the forces and acceleration, with the final equations being adjusted to account for the angle and friction. The final answer was found to be 2.29ms-2.
nvictor
In the figure
(sorry for that quick drawing with paint) m_1 (first block) = 4.0kg, m_2 = 5.0kg and the coefficient of kinetic friction between the incline plane and the first block is \mu_k = 0.24. Incline = 30 degree with horizontal
Find the magnitude of the acceleration of the masses and the tension of the cord
(1) [tex]\sum Fnet = ma[/tex]
(2) [tex]f_k = \mu_k*F_n[/tex]
I applied (1) to the first block in the x-direction and then in the y-direction
Found:
[tex]F_n - m_1*g*\sin\theta = 0 (a_y = 0) => F_n = m_1*g*\sin\theta[/tex] [a]
[tex]T - f_k - m_1*g*\cos\theta = m_1*a_x[/tex]
I applied (1) to block 2
[tex]m_2*g - T = m_2*a_y [/tex]
Added [a] to
[tex]m_2*g - f_k - m_1*g*\cos\theta = m_1*a_x + m_2*a_y[/tex]
<=>[tex]m_2*g - \mu_k *m_1*g*\sin\theta - m_1*g*\cos\theta = (m_1+m_2)a[/tex]
<=>[tex]g*\frac{m_2 - \mu_k *m_1*\sin\theta - m_1*\cos\theta}{m_1+m_2}=a[/tex]
What am I doing wrong?
Here's what we got: Force from block (2) = 9.81 * 5 = 49.05N
weight of block (1) = mg = 9.81 * 4 = 39.24
Normal reaction force = 39.24cos(30) = 33.98N
Frictional force = 33.98 * 0.26 = 8.84N
force due to gravity parallel to inclined plane = 39.24sin(30) = 19.62N
Total retarding force from block (1) = 19.62N + 8.84N = 28.46N
Tension in rope = 49.05 - 28.46 = 20.60N
There is constant tension in the rope => magnitude of acceleration is constant and equal for masses.
Mass total = 4 + 5 = 9kg
a = F/m = 20.60/9.00 = 2.29ms-2
Cross my fingers I didn't read the question wrong or make any stupid mistakes. It is ridiculously late at the moment..
Your equation has gone a bit wrong..
Fn - M1*g*cos30 = 0 will be right
M2*G - T = M2*a
T - M1*G*SIN30 - FRICTIONAL FORCE = M1*A.
i think that will give the answer.
why do you have normal force in the X direction. the normal force only apply on vertical which is y direction.
BUT THIS FORMULA IS DEPENDS ON YOUR ANGLE.
so Normal force - cos(teta)mg = 0 in the y dirction
tension -mg = am
In the x direction will be sin(teta)mg = am if there is no friction .
vishal_garg, thank you so much :D I spent the whole night banging my head again my desk trying to figure out what I was doing wrong...
Thanks for all replies
No need to say that nvictor...
well are you studying in school or college.??
College :)
great...
1. What is an inclined plane?
An inclined plane is a simple machine that consists of a flat surface that is at an angle to the ground. It is used to reduce the amount of force needed to move an object from one height to another.
2. How does an inclined plane work?
An inclined plane works by spreading out the force needed to move an object over a longer distance. This results in a smaller force needed to move the object, making it easier to lift or move.
3. What is the role of friction in an inclined plane?
Friction is the force that opposes the motion of an object. In an inclined plane, friction plays a crucial role in determining the amount of force needed to move an object. It increases as the angle of the incline increases, making it more difficult to move the object.
4. How does friction affect the efficiency of an inclined plane?
Friction reduces the efficiency of an inclined plane by converting some of the force applied into heat. This means that more force is needed to overcome friction and move the object, resulting in a lower efficiency.
5. What are some real-life applications of inclined planes and friction?
Inclined planes and friction are commonly used in everyday life. Some examples include ramps for wheelchairs or strollers, door stops, and screws. They are also used in more complex machinery, such as elevators and escalators, to make it easier to move heavy objects.
9K
