Inclined Pulley system, little information given.
The discussion revolves around solving a physics problem involving an inclined pulley system, where the user seeks to derive an expression for velocity (v) in terms of length (L), angle (theta), and gravitational acceleration (g). They assume that the tensions in the rope are equal and that the velocities of the two masses are the same, but struggle to eliminate the mass variables from their equations. Attempts to simplify the equations by assuming equal masses lead to a velocity that does not match the specified value of 1.5 m/s, indicating that the masses cannot be equal. Ultimately, the user expresses frustration over the lack of information regarding the masses, which hampers their ability to find a solution. The discussion highlights the complexities of analyzing inclined pulley systems without complete data.
alexgmcm
I have dutifully reproduced the problem in OODraw please forgive the poor aesthetic quality but I believe all the important information is visible.
mgL-Lsin(\theta)m'g = \frac{mv^2}{2} + \frac{m'v'^2}{2}
T=T'
v=v'
\therefore v^2 = \frac{2gl(m-m'sin(\theta)}{m+m'}
v = \sqrt{\frac{2gl(m-m'sin(\theta)}{m+m'}}
Also:
m'a = T-m'gsin(\theta)
ma = mg - T
\therefore m(g-a)=m'(a+gsin(\theta))
I assumed that T must be equal to T' as it is the same rope and hence can only have one tension? It just seemed to make more sense. The Lsin(theta) bit comes from the assumption that the rope length remains constant and hence m' is dragged parallel to the slope the same distance that m falls. I also assumed that v' must equal v as otherwise the rope would break, I just don't see how it could make physical sense if they weren't equal.
I need an expression for V in terms of L and theta and possibly g. That makes the second part of the question solvable. But I cannot see how to cancel the expressions for the masses out of my equations.
Any help?
You're right, there is no way to cancel m or m', because the speed depends on them.
The best you can do is set M = m/m' to get
v = \sqrt{\frac {2 g l (M - sin(\theta))} {M+1} }
Hmmm.. that doesn't help with the second part of the question though where i have to show that it is equal to 1.5ms^-1 for certain parameters, because I am not given any info about the masses or their ratios.
I wonder if we are meant to assume m=m' and the question has just been given poorly. I will see what I can get with that assumption.
Putting m=m' we get that:
v= \sqrt{gL(1-sin(\theta))}
However for L=1, theta = 20 degrees, this yields a value of 2.54ms^-1 not 1.5ms^-1 as specified in the question.
Therefore m cannot equal m'.
Unfortunately given the fact that I have no information about the masses I cannot see a solution to this problem!?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
