Initial electric field strength
The problem involves calculating the electric field strength between oppositely charged parallel plates, initially given as 3.0 X 10^3 N/C. The scenario changes with the removal of half the charge from each plate and a modification of the plate separation from 12 mm to 8 mm.
  • Participants discuss the application of the electric field equation, with one attempting to rearrange the formula based on proportional reasoning. Others question the appropriateness of the equation used, noting that it pertains to point charges rather than parallel plates.
The discussion is exploring the validity of the equation used for calculating the electric field strength in this context. Some participants are providing alternative insights regarding the correct formula for parallel plate capacitors, while others are seeking further clarification and hints.
There is an indication that the original poster is limited by the equations taught in their course, which may not encompass the necessary concepts for this problem. The discussion reflects a need for deeper understanding of electric field concepts in relation to parallel plates.
ralph344
The initial electric field strength between oppositely charged parallel plates is 3.0 X 10^3 N/C, what would the electric field strength become if half of the charge were removed from each plate and the separation of the plates were changed from 12 mm to 8 mm?
E= kq/r^2
k=9.0 X 10^9
I used proportions.
Since the formula is E=kq/r^2, i rearranged the formula to Er^2/q = k. Since the k value is going to stay constant for both.
Er^2/q = Er^2/q
[(3.0 X 10^3)(0.012)^2]/q=[E(0.008)^2]/[0.5q]
E= 3.5 X 10^3 N/C
But the answer is 1.5 X 10^3 N/C...
The electric field equation you state is for a point charge. ( and other limited cases)
But that's the only equation taught in this section... there is no other equations... anymore hints?
hey! i solved your problem! the equation you are using is that of a point charge like robb said. the electric field strength in a parallel plate capacitor is given by E=n/epsilon zero. n is the surface charge density of the plates which are equal in magnitude. the surface charge density is simply the amount charge on the plates divided by its surface area.
  • · Replies 16 ·
