Integral problem on electric potential
1 reply · 3K views · last reply
venom_h
A long metal cylinder with radius a is held on the axis of a long, hollow, metal tube with radius b. The inner cylinder has positive charge per unit length [tex]\lambda[/tex], and the outer cylinder has an equal negative charge per unit length. Calculate the potential V(r) for r<a
Va-Vb = [tex]\int[/tex]E.dr, where E can be found by Gauss's law
My only problem is why the limit for the integral is from a to b even though r < a ??
How does any point r < a experience a potential outside??
If you take the potential at infinity to be 0... then the potential at any radius r is,
[tex]V(r) = -\int_{\infty}^r \vec{E}\cdot\vec{dr}[/tex]
assuming b is the outer radius, and a is the inner radius
[tex]V(a) = -\int_{\infty}^a \vec{E}\cdot\vec{dr} = -\int_{\infty}^b \vec{E}\cdot\vec{dr} - \int_{b}^a \vec{E}\cdot\vec{dr}[/tex]
