Integrals giving me a hard time
Rectifier
Hey!
It is the first time I post on this subform. Please forgive me if I do something wrong.
F(x)=\int^x_0f(t)dt
for
R \in t \rightarrow f(t)
Is it true that
0 \leq f(x)\leq 3 for 0<x<1
\int^x_0 tf(t)dt \leq x^2
for all x \in (0, 1)? "
\int^x_0 tf(t)dt \leq x^2 \Leftrightarrow t \int^x_0 f(t)dt \leq x^2 \Leftrightarrow t F(x) \leq x^2
I don't know how to continue from here.
If I'm understanding this correctly, you could start by writing x^{2} as \int^{x}_{0}2tdt and then comparing this to the original integral. Will the inequality be valid for any value of f(x) on x\in (0,1)?
Likes 1 person
Thank you for your reply!
\int^x_0 tf(t) dt \leq \int^x_0 2t dt
Should I insert x=1(I can't insert x=0 since integrals must have bounds that are not equal)? What should I do with the f(t)?
EDIT:
Sorry, I just started this chapter and I am not so sure what to do.
You could rewrite the inequality as
\int^{x}_{0}[f(t)-2]tdt\leq0
Now, since x \in (0,1), the t will clearly not be negative on the interval, meaning f(t)-2 will either oscillate between positive and negative values, or will just be negative (since their product must be negative on at least one subset of (0,1) for the whole integral to be negative or zero). Now, since f(t) can be ANY function (as long as f(t)\in(0,3)), you can sometimes pick it to be the simplest one, in this case a constant. Can you then choose a constant f to simultaneously satisfy the above inequality and the initial assumption?
Likes 1 person
Thank you for your reply once again!
I could pick f(t)=2 that will satisfy the inequality. But if I choose f(t)=3 it will mean that the inequality is wrong since the integral will be postitive. I guess that means that the initial inequality is wrong.
Is that right?
Rectifier said:
Hey!
F(x)=\int^x_0f(t)dt
for
I don't understand what the above is supposed to mean. Can you explain in words what you're trying to convey here?
Rectifier said:
Is it true that
The wording here is somewhat confusing, IMO. What part is given (or we are supposed to assume) and what part are we to show? IOW, are we supposed to verify that 0 ≤ f(x) ≤ 3 when 0 < x < 1?
And then show that the inequality is true?
You can't pull t outside the integral like you have done above.
You are giv
Is that right?
Yup, you found a counterexample, so the initial theorem doesn't hold, that's all there is to it.
Likes 1 person
You are giv
Thank you for your post.
I am having a hard time translating the problem to English from Swedish. We were supposed to verify if the inequality is true having (0 ≤ f(x) ≤ 3 when 0 < x < 1) as our starting conditions.
Thank you :)
