Integration and Laplacian in polar coordinates
chilge
I have a function y that is axisymmetric, so that y=y(r).
I want to solve for r such that ∇2y(r) = Z.
Can anyone tell me if I'm following the right procedure? I'm not sure since there are two "∂/∂r"s present...
2 = (1/r)(∂/∂r)(r*(∂/∂r)) + (1/r2)*(∂2/∂θ2)
--> The terms involving theta become zero since y is a function of r only
2y = (1/r)(∂/∂r)(r*(∂y/∂r)) = Z
(∂/∂r)(r*(∂y/∂r)) = Zr
integrate with respect to r: r(∂y/∂r) = (1/2)Z*r2 + C
(∂y/∂r) = (1/2)Zr + C/r
integrate with respect to r again: y = (1/4)Z*r2 + Cln(r) + K
Looks fine to me. If you substitute that back into the original equation you do get Z, right? That's a good way to check.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
