Integration By Parts: Solving int.arctan(2x)dx for Calculus Homework
The discussion revolves around the integration of the function arctan(2x) with respect to x, specifically using the technique of integration by parts. Participants are exploring the correct approach to solve the integral and verifying the results of their attempts.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to solve the integral using integration by parts and seeks confirmation of their answer. Some participants suggest checking the differentiation of the antiderivative to verify correctness. Others discuss a substitution method involving u-substitution to simplify the integral.
The discussion is ongoing, with participants providing feedback on each other's attempts. There is a suggestion to verify work through differentiation, and alternative methods are being explored without a clear consensus on the correct solution yet.
Participants are navigating through the complexities of integration techniques and are considering the implications of their chosen methods. There is an acknowledgment of potential errors in the original poster's calculations, prompting further investigation.
mike01
Integration By Parts?
int.arctan(2x)dx
In the attached image is the original problem with the ansewer I came up with using integration by parts and then a v=sub. later in the problem I did not want to post additional steps because it turned out to be a longer problem than I thought Just curious if someone could confirm my ansewer and if it is incorrect I will post the work to help see where I messed up. thanks a ton.
I differentiated your antiderivative and I didn't get arctan(2x). If you want to check your work in the future, you could try that too. You can often get a clue where you messed up by looking at that as well.
thanks I will see if I can figure it out.
Yeah i almost got the same thing, except for the (1/4) looks like just a u-sub
Integral of arctan(2x) dx... u=2x du=2dx dx=(1/2)du
so now we have (1/2) integ arctan(u) du
leave the (1/2) out in front as a constant and I got u*arctan(u)-ln(sqrt(1+u^2))
plug everything back in and i got x*arctan(2x)-(1/2)ln(sqrt(1+4x^2)) ... but I just used a table for arctan(u)
  • · Replies 22 ·
  • · Replies 18 ·
