Integration by parts VS. Formula in text
Saladsamurai
I am either making the same mistake repeatedly, or I can't factor!
I did this \int\ln(2x-3)dx first by parts and then using the formula \int\ln u du=u\ln u-u+C
By parts I got:
u=\ln(2x-3) dv=dx
so =x\ln(2x-3)-\int\frac{2x}{2x-3}dx and by long division:
=x\ln(2x-3)\int [1+\frac{3}{2x+3}]dx
=x\ln(2x-3)-x-\frac{3}{2}\ln(2x+3)+C
but I can't get that to match the formula result of
(2x-3)\ln(2x-3)-(2x+3)+C
Is the by parts correct?
Casey
I am getting closer, but I must have screwed up a sign or something in the Int by parts...but I can't see where ...
that's what i got, let me take the derivative and to check.
Okay, so I have fixed a sign error and I get from parts:
x\ln(2x-3)-x-\frac{3}{2}\ln(2x-3) and then multiplying thru
by 2 I get 2x\ln(2x-3)-2x-3\ln(2x-3) which is extremely close...but I can't figure out how to factor it properly...
Almost there :)
I just can't figure out to do with that -2x in the "middle" its a term not a factor...
For one,
should have a minus sign within the integral.
In the following step, you've multiplied the - outside the integral(that's supposed to be there :wink:) with that +.
it checks out after taking the derivative.
neutrino said:
For one,
I don't follow. If I do that integral off to the side I get x+(3/2)ln(2x-3)
and then i distibuted the - sign...
EDIT: I see, I just forgot to put it in the 1st post...scroll down to post#4
What does? from which post#. I can't get it to match the formula.
Casey
first post, except that the last ln should be ln(2x-3)
i hate the tables, i prefer hand-method :p takes too long and comes with errors because i suck, but is all good.
My goal though is to get what I got in post #4 to look like the formula from the textbook which looks like this (2x-3)\ln(2x-3)-(2x+3)+C
but I have 2x\ln(2x-3)-2x-3\ln(2x-3)+C
which is close...how does that factor?
If I factor that don't I just get (2x-3)\ln(2x-3)-2x+C ?
why can't I factor this:smile:??!
lol that's really hard ... quit obsessing!
But it is part of the assignment!
to put it in table form? eek!
i got:
\ln{(2x-3)}[2x-3]-x ...
but idk what to do after that. and how did you get -2x?
Maybe it's because what you're trying to find is an indefinite integral, and the answers to different methods employed usually differ by a constant.
This might help:
-x+C=-\frac{1}{2}(2x)+C=-\frac{1}{2}(2x-3)+C-\frac{3}{2}=-\frac{1}{2}(2x-3)+C_1
In which C_1=C-\frac{3}{2} another constant is.
salad, I can't quote your post, browser issues. But your "book formula" integral is in error.
(2x-3)\ln(2x-3)-(2x-3)+C
should read
\frac{1}{2}[(2x-3)\ln(2x-3)-(2x-3)]+C
(I corrected your sign error)
You cannot in general just use a formula for an integral of f(u) with a direct substitution of u=g(x) into the result. This is because what you are actually doing with a proper substitution is
\int{f(g(x))}dx = \int{\frac{dx}{du}[f(u)]}du = \int{\frac{f(u)}{u'}}du
In this case, u'(x) = 2, so you should divide the final expression by two.
I did not check your integration by parts, but the above correct answer for the formula method tallies with it, except for a constant term :
x\ln{(2x-3)} - x - \frac{3}{2}\ln{(2x-3)} = \frac{1}{2}(2x)\ln{(2x-3)} - \frac{1}{2}(2x) - \frac{1}{2}(3\ln{(2x-3)}) = \frac{1}{2}[(2x-3)\ln{(2x-3) - 2x}] = \frac{1}{2}[(2x-3)\ln{(2x-3) - (2x - 3)}] + C
which all works out.
