Intersection Line for Two Planes
The discussion revolves around finding the equation of the line where two planes, Q and R, intersect. The planes are defined by the equations Q: -2x + 3y - z = 1 and R: x + y + z = 0.
  • Mixed
  • Participants explore the method of finding a common point on both planes and the direction vector through the cross product of the normal vectors. There is a discussion about different parameterizations of the line and the implications of using different starting points.
Participants have acknowledged that the original poster's answer and the answer key represent different parameterizations of the same line. There is a recognition that both answers are valid in the context of the problem, and some participants express confidence in the correctness of the original poster's approach.
Some participants question the phrasing of the problem, noting that it asks to 'find an equation of...' rather than 'find the equation of...', which may imply multiple valid representations. There is also a light-hearted exchange regarding the clarity of the original poster's equation.
kieth89
Find an equation of the line where the planes Q and R intersect.
[itex]Q: -2x + 3y - z = 1; R: x + y + z = 0[/itex]
Equation of a Plane: [itex]ax + by + cz = d,[/itex]where [itex]\vec{n} = <a, b, c>[/itex]
Equation of a Line in [itex]R^{3}[/itex]: [itex]\vec{r}(t)=<x_{0}, y_{0}, z_{0}> + t<x,y,z>[/itex]
First I find a point common to both planes, this will be [itex]P_{0}[/itex].
Set [itex]y = 0[/itex] and add the plane equations:
[itex]-2x + 0y - z - 1 = 0[/itex]
[itex]1x + 0y + z - 0 = 0[/itex]
Resulting in: [itex]-x - 1 = 0[/itex] so [itex]x = -1 , z = 1[/itex] and [itex]P_{0} = (-1, 0, 1)[/itex].
Now I find the direction vector for our line. This will just be the cross product of the normal vectors from the two plane equations:
[itex]<-2, 3, -1> X <1, 1, 1> = <4, 1, -5>[/itex]
Now I just plug the obtained info into the equation for a line:
[itex]\vec{r}(t) = <-1, 0, 1> + t<4, 1, -5> -> \vec{r}(t) = <-1 + 4t, t, 1 - 5t>[/itex]
I felt pretty confident in this answer, but the answer key says it should be [itex]<-\frac{1}{5} + 4t, \frac{1}{5} + t, -5t>[/itex]. I'm wondering if my answer is different due to using a different [itex]P_{0}[/itex], but I don't know...
The answers are just different parametrisations of the line.
If we label your ##t## as ##t## and theirs as ##t'## then the conversion is ##t'=t-\frac{1}{5}##.
This is hinted at by the question asking you to 'find an equation of...' rather than 'find the equation of...'
Strictly speaking though, neither answer is correct, as neither is an equation - where is the equals sign? But there is no single equation that denotes the line. Two are needed.
Your equation is correct and also the given solution is really a parametric representation of the line of intersection. The difference is the starting point only. The equation of a line is given by ##\vec r(t) = \vec a + \vec b t##
The answer of the OP is an equation. It has two sides and a "=" in between. :smile:
Yay! So it is due to different starting points. Thanks for the help everyone.
Oh my goodness, so it does! I don't know how I missed that. Either my mind's been playing tricks on me or my vision is deteriorating even faster than I feared.
