How Far Will a Race Car Travel After Running Out of Gas?
A race car weighing 10,000 kg traveling at 10.0 m/s will continue to move after running out of gas until it comes to a stop, but the distance it travels depends on the frictional force acting against it. The discussion highlights the need for the coefficient of friction to determine the retarding acceleration, which is essential for calculating the stopping distance. Without this information, the problem becomes significantly more complex. Participants emphasize the importance of breaking down the problem into manageable steps rather than attempting to solve it all at once. Ultimately, the lack of sufficient data is a major obstacle in finding a solution.
irNewton
A race car with the weight of 10 000 kg is traveling at 10.0 m/s when it's gas runs out. How far will this race car travel till it reaches an absolute halt?
F=ma
v2^2-v1^2=2ad
Fn= 490 000N
v2^2-v1^2/2d= a
and I tried to sub that for a in F=ma, but got no where =/
You are not providing the enough information.
1) What is the frictional force?
- How you get frictional force provided that normal force is given?
2) So what is retarding acceleration?
Find that acceleration before doing anything. Don't try to solve it all in one single step.
Hi, well we aren't given the coefficient of friction which makes this question ten times harder -.-
Or I could have easily figured this out myself...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
