Is it Possible to get over 90% efficiency from a servo motor
Achieving over 90% efficiency from a servo motor is possible, particularly with a 3-phase synchronous motor using sinusoidal commutation and careful control of the power factor (cos φ). The efficiency can vary based on the specific motor design. Implementing a digital voltage controller with an encoder to monitor rotor position is essential for optimizing performance. Utilizing a gearbox will affect overall efficiency, as no gearbox operates at 100% efficiency. Most servo motors used in positioning applications typically exhibit lower efficiency levels.
Fizzics
...If so what would the highest figure be whilst running a 1kw (single or 3 phase) motor under normal conditions also would using a 10:1 Gearbox change that efficiency level?
Yes, it is possible: Use a 3 phase synchronous motor with sinusoidal commutation, and control cos φ carefully. Cos φ shall not be exactly 1.0, but close to. The value depends on the motor.
You must use a digital voltage controller, that reads the angular position of the rotor by means of an encoder.
Of course a gearbox will change the efficiency: No gearbox has an efficiency = 100%
The efficiency of most types of servo motors actually used for servo positioning and similar applications is often quite low .
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
