Is the Natural Log of Pressure Unitless?
The discussion centers around the application of the Clausius-Clapeyron equation and Trouton's rule to determine the pressure of mercury at its boiling point. The primary concern raised is the unitlessness of the result when calculating the ratio of pressures (P2/P1) using logarithms. Participants clarify that taking the logarithm or exponential of a quantity with units is nonsensical, as these operations inherently require unitless values. The equation ultimately leads to a unitless ratio, which can then be multiplied by a known pressure (P1) to find P2, retaining the appropriate pressure units. The conversation emphasizes the importance of understanding how units cancel out in the calculations and reassures that the algebra is sound, with no mistakes in the approach. The discussion concludes with a consensus that the calculations are correct and that the confusion regarding units is a common misunderstanding in the application of these equations.
ChrisW
Ok so i was doing a problem involving finding the pressure of mercury at its boiling point (630.05K) using Troutons rule and the final answer seems a bit strange to me.
Integration of the Clausius-Clapeyron Equation:
{ln(\frac{{P}_{2}}{{P}_{1}}) = -\frac{{\Delta}_{vap}\overline{H}}{R}(\frac{1}{T}_2-\frac{1}{T}_1)
So... you end up with a number, but it's unitless? What am I missing? Thanks.
Troutons rule states that at standard T and P:
{\Delta}_{vap}\overline{S} \approx {88} {J}\cdot{K}^{-1}\cdot{mol}^{-1}
and the change in entropy is related to the change in enthalpy by:
{\Delta}_{vap}\overline{H}={\Delta}_{vap}\overline{S}\cdot{T}_{vap}
Chemistry news on Phys.org
ChrisW said:
(snip)Integration of the Clausius-Clapeyron Equation:
Correct
What am I missing?
Nothing --- well, maybe you should take another peek at the expression (P2/P1).
another hint is that you can never take logs or exponentials with anything that has units. it simply makes no sense.
Yes, this was the heart of my question. We use Troutons rule to determine the pressure at the vaporization temperature, yet to do this we must take the exponential of the equation. So, for instance:
{ln(\frac{{P}_{2}}{{P}_{1}}) = -\frac{{\Delta}_{vap}\overline{H}}{R}(\frac{1}{T}_2 -\frac{1}{T}_1)
{\frac{{P}_{2}}{{P}_{1}} = e^{-\frac{{\Delta}_{vap}\overline{H}}{R}(\frac{1}{T}_2 -\frac{1}{T}_1)}
{P}_{2} = e^{-\frac{{\Delta}_{vap}\overline{H}}{R}(\frac{1}{T}_2 -\frac{1}{T}_1)}{P}_{1}
Are units retained after taking the exponential of ln(\frac{{P}_2}{{P}_1})? I mean I understand you're still taking the exponential of a unitless number because it's pascals/pascals, but my instructure mentioned that there was a special circumstance that kept the units around... Perhaps it is just simple math and he's just confusing us all :smile:.
I also realize that the title of my post is misleading, sorry about that. ;)
? I mean I understand you're still taking the exponential of a unitless number because it's pascals/pascals, but my instructure mentioned that there was a special circumstance that kept the units around... Perhaps it is just simple math and he's just confusing us all .
if you take the exponential you will still have a unitless equation. like you said you will have p2/p1 so units will cancel out. Sure you can mutiply both sides by p1 to get p2=e^(stuff)p1 and you have an equation with pascals on the left and pascals on the right. But that just means you can still cancel out units. Don't get confused by playing around with the algebra. No matter how you play around with the equation, the units will always end up canceling out. Just ask yourself what is the ln(cm) or ln(bars) or e^cm or e^J. These unit quantities make no sense. I am 99.9% sure there are absolutely no cases where you can take the log or exponential of a quantity that has units.
I was not confused by the algebra at all. Really what I wanted to find out was that my answer, which I obtained from the very equation for P2 I posted above, was correctly stated as a pressure. The basic algebra of the problem made sense to me, however my instructor circled the units on my answer and noted in class that the reason was due to the logarithm. I wanted to see if I could figure it out on my own and I came to the conclusion that my answer was right, just wanted to make sure I wasn't making a mistake.
Thanks.
I really don't see the problem. You get an expression P2/P1 that is unitless for obvious reasons - the units cancel out on division. If P2/P1 = x then P2 = x times P1, P1 having a (arbitrary) unit of pressure like bar, kPa, atm, psi etc. and x being unitless. The only thing I wonder about is how to get P1 and T1... :rolleyes:
i didn't see the problem either! i took my paper back and received full credit :wink:.
as for finding P1 and T1, it's just more algebra.
