Is There a Geometric Link Between the Ratios in Eratosthenes' Experiment?
The discussion centers on the geometric relationship between the shadow of a pillar in Alexandria and the distance between Alexandria and Syene, both of which are in a 1-to-8 ratio. It is noted that during the summer solstice, the sun is directly overhead in Syene, which is crucial for understanding the experiment conducted by Eratosthenes. Participants express curiosity about the meaning of a "geometric connection" between these ratios. A simulation of the experiment is shared to illustrate the underlying geometry. The conversation emphasizes the significance of these observations in understanding Earth's dimensions.
NateTheGreat
The Shadow cast by a vertical pillar in Alexandria at noon during the summer solstice is found to be 1/8 the height of the pillar. The distance between Alexandria and Syene is 1/8 the Earth's radius. Is there a geometric connection between these two 1-to-8 ratios?
Not sure exactly what kind of answer they are looking for here.
Welcome to PF!
Hi NateTheGreat! Welcome to PF! :smile:
You've left out that at noon during the summer solstice, the sun at Syene is directly overhead.
(I know that 'cos this is a well-known experiment by Eratosthenes in about 200 BC :wink:)
Does that help? :smile:
Ah! So then would that explain why they are both 1/8 of the Earth's radius? I'm trying to figure out what they mean by a "geometric connection"?
Look at this flashy simulation of the experiment, it is a demo but you can see from it the basic geometry used.
http://www.edumedia-sciences.com/a287_l2-eratosthenes-experiment.html"
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
