Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The Fukushima Daiichi nuclear plant is facing significant challenges following the earthquake, with reports indicating that reactor pressure has reached dangerous levels, potentially 2.1 times capacity. TEPCO has lost control of pressure at a second unit, raising concerns about safety and management accountability. The reactor is currently off but continues to produce decay heat, necessitating cooling to prevent a meltdown. There are conflicting reports about an explosion, with indications that it may have originated from a buildup of hydrogen around the containment vessel. The situation remains serious, and TEPCO plans to flood the containment vessel with seawater as a cooling measure.
  • #2,901
orndorf said:
If the plan is to pump out all the highly radioactive water from the basements of reactors 1-3 won't the radiation levels outside skyrocket?
They have a choice of pumping the contaminated water into a barge or into the ocean. That would increase the activity around the barge or in the ocean.
The water in the basement is shielding the upper levels and outside from higher levels of radiation right?
The water in the basement may provide some shielding of whatever the water is containing. Given that they put clean water in and get contaminated water out, this would indicate a leak somewhere in the containment or some affiliated piping system.
Given that they still need to cool the core, they need to replace the water that leaks - or stop the leak and ensure a closed cooling system, if that is possible. Otherwise, they have to collect the contaminated water and store it somewhere, and otherwise, release the contaminated water to the ocean.
  • #2,902
Thank you Tcups, I'm glad to contribute to the collective quest for plosive answers that you lead for a fair amount .
There is one thing that I'm still not to confident with :
What are we seeing bellow the arrows It is supposed to be a strait wall.. How do we explain what we are seeing ?
[PLAIN]http://i.min.us/ikEmCk.jpg
  • #2,903
shogun338 said:
The sound in that video has been added in by someone . I have the video of Unit 3 exploding and there is no sound like that . Where did they get the sound that was added to the video ?
No it's not added in, that was the sound on the live coverage, its just never been repeated as far as I know since.
  • #2,904
shogun338 said:
The sound comes to soon . Even if the camera was only one mile away it would take the sound of the explosion around 5 seconds or more to reach camera . Camera is more than a few miles away .
That sound is Definately Added afterwards. Also there was a 20km exclusion zone around the plant and I suspect these images are from that distance, they said the number 3 blast was heard 40km away but I'll be surprised if anyone recorded it.
  • #2,905
Giordano said:
This is crazy high... Is it really sea water? It's not water taken directly from the leak!?
http://www.meti.go.jp/press/2011/04/20110405007/20110405007-4.pdf shows several kinds of samplings :
物揚場前 in front of the quay
2号機スクリーン海水 sea water at unit 2 screen
スクリーン流入水 water flowing into the screen
ケーブルピット水 cable pit water
(Edited to remove my big unit mistake , as Giordano mentions below)
  • #2,906
tsutsuji said:
5400 Bq/kg is not as crazy as the 15000 Bq/kg they found in the spinach at Kitaibaraki (70 km south of the plant) on 19 March and whose sales are now stopped : http://www.mhlw.go.jp/stf/houdou/2r98520000015iif-att/2r98520000015jpm.pdf
スクリーン流入水 water flowing at the screen
5.4 Mbq/cm3 corresponds to 5 400 000 000 Bq/kg of water
  • #2,907
  • #2,908
|Fred said:
Thank you Tcups, I'm glad to contribute to the collective quest for plosive answers that lead for a fair amount .
[PLAIN]http://i.min.us/ikEmCk.jpg[/QUOTE]
Well, if the theory is that the FHM went ballistic and crashed downward through what was left of the roof on that side of the building, there could have been quite a bit of debris that ended up in the equipment pool -- parts of the roof, the FHM itself, etc.
Photoshop says it is some sort of complex, box-like structure partially covered with debris and with a bit of sun and shadow thrown in just for fun. Some piece of equipment? Don't know, but it is clearly in the pool and appears to be separate from and in front of the common wall with the upper dry wall containment.
An upright piano, maybe?
http://i306.photobucket.com/albums/nn270/tcups/Screenshot2011-04-05at74000AM.png
http://i306.photobucket.com/albums/nn270/tcups/Screenshot2011-04-05at74307AM.png
http://i306.photobucket.com/albums/nn270/tcups/Screenshot2011-04-05at73942AM.png
. . . no -- here is a shot straight down into the pool with the shadows brightened:
http://i306.photobucket.com/albums/nn270/tcups/Screenshot2011-04-05at75953AM.png
  • #2,909
TCups said:
VIDEO WITH AUDIO OF UNIT 1's EXPLOSION?
Can anyone find the video of Unit 1 exploding with an audio track instead of a voice over? If both videos were taken from about the same place, it would be very interesting to count the booms. If Unit 1's explosion has only 1 boom and Unit 3's has 3 booms, then they aren't echoes. Conversely, if Unit 1's explosion also has 3 booms, then they are echoes.
I must get dressed and get to work . . .
Watching live I only remember one boom with unit 1, and it was noticeable enough for me to think "That's odd" there being three explosions on the live pictures and sound with three
  • #2,910
Sorry.
I have edited my post.
So the sea water in front of the quay with 360 000 Bq/kg on April 3rd, then 640 000 Bq/kg on April 4th is worse than the spinach.
  • #2,911
I hope this will help (based on a patent filled by Hitachi (who manufactured with GE some of Fukushima plant)
this is the looking from the sea / east => weast
81 equiment pool
33 SFP
33a fueal rack
http://i.min.us/imZjAC.jpg
this is a south/north or north /south view
http://i.min.us/imUTuC.jpg
and this is .. well
http://i.min.us/imZlIK.jpg
full legend here http://www.freepatentsonline.com/6744841.html
  • #2,912
Excellent diagrams.
Can't find with sound but from this vid the vertical pressure wave does follow the first blast.
Zoomed in at 35 seconds.
  • #2,913
The newest sea water data collected about 25 nautical miles away from the plant are available at http://www.mext.go.jp/component/a_menu/other/detail/__icsFiles/afieldfile/2011/04/04/1304149_0404.pdf
  • #2,914
And in English:
http://www.mext.go.jp/component/english/__icsFiles/afieldfile/2011/04/04/1304193_0404.pdf
  • #2,915
Cire said:
Thermocouples have a known failure mode when overheated. First the precision opens up and then an offset develops. It's call decalibration and the sensor will return what appears to be a correct value, when it isn't.
This is why the IAEA keeps saying "The validity of the RPV temperature measurement at the feed water nozzle is still under investigation."
The fact that the water feed nozzle is showing a higher temperature (253 °C in unit 1) is a good indication of a failure. The feed water nozzle has the highest flow of the coldest water in the reactor at this time. At these injection rates the reported temperature is not correct.
Thank you for the explanation.
  • #2,916
Well, we are looking down at the equipment pool, essentially a straight-walled rectangular pit. The wall at the far end of the pit is where it interfaces with the reactors top area. This wall appears bright at the top, and darker below, your upper arrows points approximately to where the color changes. The bright part I interpret as some concrete top slab, designed to fit into the concrete slabs that lies on top of the reactor, and below other slabs, vertically jigsawed together, so to speak to form a wall. Several objects have fallen into the pit, most conspicous is a huge rectangular slab, which is leaning across the pit from the bottom left wall, and almost to the top right wall. it can be seen as a grey object just below your lower arrow. I looks to me as a kind of gate that fits in at the far wall, covering the slabs
  • #2,917
Two additional things to note from those images. The location of the steam appears heavily discoloured black (on the beam). This is visible on the later clip where no steam is venting.
Secondly, on the side opposite the location of the red arrows, there is seemingly a void where the main floor slab has been blown out, or collapsed in. At least, that's how I read it given my assumption there were no openings in the floor on either side of the SFP delivery channel.
/edit : From the angle the image is taken, the black area should be the outside wall of the containment vessel in shade. Surprised it's SO black considering it's proximity to the opening giving us the view through along with enough daylight to provide some illumination.
  • #2,918
"The fact that the water feed nozzle is showing a higher temperature (253 °C in unit 1) is a good indication of a failure." is the wrong conclusion - Unit 1 temperature is correct and unit 3 temperature is incorrect and under review. Below the before and after event of unit 3 thermocouple failing. As we can see from below data Tepco had a double emergency
Unit 1 and 3 exceeding design temp of 300 degrees on 23rd. Also, Unit 3 flow rate measurement had malfunctioned such no indication of how much water was being pumped.
23 March : http://www.meti.go.jp/press/20110323012/20110323012-4.pdf
Black smoke from reactor 3 reported
24 March : http://www.meti.go.jp/press/20110324003/20110324003-3.pdf
  • #2,919
FishmanGeertz said:
I hope that nuclear power plants all around the world are given safety upgrades to make sure than the Fukashima incident can not happen again.
Are nuclear power plants in earthquake-prone areas such as in California, vulnerable to having their cooling systems knocked out by earthquakes and tsunamis?
That question should be on another thread. San Onofre only has a 29 to 30 foot sea wall and is, in my opinion at risk. The sea wall needs to be built higher.
  • #2,920
PROPOSED MECHANISM FOR 3-PHASE EXPLOSION OF BUILDING 3
|Fred said:
Dear Panzer-armadillo
I'm a not to fresh those days.. Probably need more sleep. I apologize if I don't get you the first time.
[PLAIN]http://i.min.us/ikuqtC.jpg
I have the impression that we are seeing something like this..Why do you think the explosion toke place bellow the slab?.
H leaked likely on the SFP side, the ignition toke place on the south wall above the SFP it only blew the operating floor south wall
Does it mean the pool was empty or full ? I'll go for full
How do we explain the upward explosion catapulting the FHM in the air?
Cheers
|Fred:
The short answer is that a hydrogen explosion on the top floor does not explain what we see and cannot launch the FHM upward. That is the key.
The only thing that launches the FHM upward is steam, because if all the water is gone, then the pool is just full of hydrogen like the rest of the upper floor and there is no differential pressure under the FHM when it blows.
How do we get steam under the FHM? Only way is superheated gas blasting out the transfer chute.
How does that happen? The containment is full of nitrogen and hydrogen venting occurs to the outside of the containment.
Remember the lateral acceleration forces from the 9.0 quake that exceeded the design parameters of Unit 3? I was wrong about the weak spot being the torus-to-primary containment link.
Here is a radiologist's interpretation of Fig. 3, which is the critical information needed here.
http://i306.photobucket.com/albums/nn270/tcups/Screenshot2011-04-05at100427AM.png
That big old steel reactor vessel sets on a pedestal like a long, skinny boiled egg. It is made of heavy steel, and it is full of water and one of the densest things I know of -- uranium.
The structures in red are pneumatic shock absorbers of some sort. They are intended to stabilize said "egg" in an earthquake if anything gets tippy.
The torus is in the ground and all that massive concrete structure, not to mention the steel liner inside the primary containment are MASSIVE and firmly anchored to the ground.
If the lateral acceleration forces exceed the design parameters, the pressure vessel risks becoming the upside down clanger in a giant bell shaking at about a 9 on the Richter scale.
The key vulnerable structure if that happens is the high pressure steam outlet pipe. If that cracks or leaks, then you have high pressure steam and shortly thereafter, hydrogen in the primary containment, but not in a huge blast, as the torus suppression pool is meant to (hopefully) handle. Apparently that didn't work out so well at Unit 2.
Now, I can put live steam and hydrogen gas in the primary containment displacing the nitrogen. I can't tell you the exact route to the lower building -- probably via the torus pool then lower floors and up through the lift shaft.
Anyway, pressure differential vs. atmospheric pressure in the vessel doesn't go to zero, but neither does the pressure build to the same level as an RPV without the damaged pipe and leak. Operators might interpret that as "hold off a short while and let's hope to God the generator gets hooked up and we can cool this off before the pressure goes too high, because Unit 1 exploded when we had to do that the last time!" *
Addendum:
*actually the operators had already manually vented the primary containment at 8:42 AM -- but perhaps this also let to more hydrogen in the upper containment, but it means the leak, if there was one either was not so large as to negate the need to vent the RPV, or, perhaps that the rising pressure in the RPV added to the severity of the leak before it was vented.
In the meantime, some hydrogen could have escaped the the drywell cap seal as well as the transfer gate seal, maybe even a pressurized stream venting to the upper building.
The reactor vessel is now mostly dry, really, really (red?) hot, and making hydrogen and oxygen. **
Addendum: ** the explosion(s) occur at 11:15 AM. Thanks for the timeline chart (below)
BOOM! Gas in the primary containment ignites, blows the drywell cap, and blows out of the transfer chute, and to a lesser extent, out of the gate to the equipment pool. This 1) causes a secondary explosion of the hydrogen above, but more importantly, 2) vaporizes the remaining water in SFP3, turning it into a steam cannon and the FHM goes ballistic. BOOM!
The fire and explosion in the upper building propagates to the lower floors which have their own hydrogen, but the pressure from above means that the primary force of the tertiary explosion in the lower floors goes outwards through any path it can find. BOOM!
Now you have the mechanism for the initial fireball at the southeast corner, a ballistic FHM, damage to the equipment pool, blown out upper building, and blown out lower building including the access tunnel, all without a gross breech of the RPV (ie, melted fuel melting through the steel of the RPV).
Debunk that. :biggrin:
  • #2,921
Very interesting I'll have to analyse that, have you worked out what the big 'jet' of dust is that heads north and obscures from view the northern most exhaust chimney?
good chart on wiki:-
http://upload.wikimedia.org/wikipedia/en/2/2f/Fukushima7.png
  • #2,922
@tcup
read and agreed up to "Now, I can put live steam and hydrogen gas in the primary containment displacing the nitrogen" Will continue later ..
Ps: your quoted me in a private message .. now everyone know your pet name...
  • #2,923
That appears to be a "How to decommission a BWR".
I'm not sure how it will work with the current units.
They have a massive decontamination job on their hands, even if they entomb the units, there's a lot of water that would need to be displaced and therefore cleaned up.
  • #2,924
|Fred said:
@tcup
|Fred et. al: the "Panzer-armidillo" is the "Tarkus", taken from the vintage 1971 (the year I graduated high school) ELP album of the same name, and still one of the finest rock albums ever made.
"TCups"
http://i306.photobucket.com/albums/nn270/tcups/TCUPS2.jpg
http://www.rockalbumreviews.co.uk/wp-content/uploads/2009/08/tarkus.jpg
  • #2,925
The silence has been broken.
"The monitor told NHK that no one can enter the plant's No. 1 through 3 reactor buildings because radiation levels are so high that monitoring devices have been rendered useless. He said even levels outside the buildings exceed 100 millisieverts in some places".
http://www3.nhk.or.jp/daily/english/05_38.html
  • #2,926
You explain to everyone how the sound traveled so far that fast . Camera was miles away . Sound does not travel that fast .
  • #2,927
Fred said:
[PLAIN]http://i.min.us/ikuqtC.jpg[/QUOTE]
This estimated damage looks consistent with the Oyster Creek sketch, where the upper part of the pool wall seems to be made of interlocked concrete rings...
[PLAIN]http://img847.imageshack.us/img847/7598/oysterplug.jpg
  • #2,928
=>The only thing that launches the FHM upward is steam
ok
=>The steam comes from a leak in the drywell
ok
shouldn't we have witness some kind of quick pressure release in the drywell just after the blast?
# date ! time ! hour ! water ! Pcore ! Pdryw ! Psupc ! X ! SRC !
2011-03-14 | 9:00 | 81.0 | -1500 | 409 | 490 | 475 | 0 | --- |
2011-03-14 | 11:01 | 83.0 | 99999 | 99999 | 99999 | 99999 | 1 | --- | < boom
2011-03-14 | 11:15 | 83.2 | -1600 | 316 | 380 | 390 | 0 | --- |
2011-03-14 | 11:25 | 83.4 | -1800 | 292 | 360 | 380 | 0 | --- |
Delta 110MpA
  • #2,929
ok
ok
The vertical component of the blast seen on the explosion video of Unit 3 IS the steam. The blast out of the chute would not give a significant upward vector. However, if the residual water in the bottom of the SFP were "pre-heated" so, to speak, near or at boiling point, then I could imagine the sudden addition of the thermal energy blowing out the chute and directly over the residual water in the pool gives the "kick" needed to start the steam engine. I don't know if that makes perfect sense, but it is all I can conceive to put enough kinetic energy under the FHM.
As I think about it, remember also the apparent position of the FHM seen at Unit 4 (at the back (south) edge of the SFP). The sidewise blast therefor might initially tend to be concentrated under the FHM and against the south wall of the SFP.
The quick release of energy would be an explosive expansion of the phase change of water to steam. Almost like a boiler exploding, maybe?
And is it the consensus that the FHD actually did go ballistic? I am not sure that has been independently confirmed, so as yet, that is just the best interpretation of the visual evidence, but not a proven fact, right?
As for the pressure inside the drywell and inside the RPV, I have not examined that data. I will have to defer to you or others on that point, Fred. I am not sure I follow the tabular data above. What is the 99999 figure? Is that absolute or relative pressure?
The explosion outside the RPV might not affect the pressure inside the RPV. The pressure in the drywell does drop after the expolsion (units?). What is Psupc? What is a normal drywell pressure? When was the drywell flooded?
  • #2,930
My only explanation is that the camera is not as far away as was reported, the film is that which was transmitted on the night, I had Sky on the TV and NHK on the laptop, and was watching to see if there was a difference in coverage between local and foreign media. The showing of that chunk of film with sound was far too soon after the explosion for anyone to have inserted fake explosion sounds onto it.
  • #2,931
I interpret the 99999 as nodata a way of inserting an event in the graph
  • #2,932
Perhaps the blasts occurred prior to the visual emergence of the fireballs and ejection of debris.
  • #2,933
ChopperFlyover said:
you talk about rods laying around but #4 rebar is kinda like a pencil's diameter and hanging out of broken concrete all over the place along with other size rebar. Rebar doesn't shine
It doesn't seem rebar. Those rods seem fairly rigid and are all collected together, parallel, in a place where rebar is unlikely to have collected in large amounts. Moreover the rebar in the outer skin is arranged like a grid.
The neutron measuring tubes, proposed by another poster, seem a much better explanation. Are those neutron tubes gathered into square assemblies too, like the fuel rods?
  • #2,934
Were starting with superheated water (like a glass of pure water heated in a microwave). If a (relatively) small leak (re: failure at seal of cap) blew out sideways through the transfer gate, there would be a sudden rapid expansion of volume in the remaining liquid. The pressure would increase so rapidly that any other weak point, including an overstressed torus could give way.
99% steam?
  • #2,935
Right. Sometimes the 99999 is a TEPCO fax that says "no data" for that variable, sometimes it is some other source (like an explosion report) that does not mention the variable.
The "Main.html" page in that directory has more details on the file format.
  • #2,936
99% steam?
Notice the apparent color of the plume in this boiler explosion. :http://www.google.ca/url?sa=t&sourc...ElT6Rt4Wg&sig2=Mkl-1gUSN-BzZPjk4Gd9fQ&cad=rja
  • #2,937
Note, that was a Carbon Fuel Burning Boiler. More than likely tubes with hot water on the inside and carbon dust on the outside where the flames of combustion are. When the tube bursts it kicks up a lot of carbon soot (and probably put the fire out).
  • #2,938
TCups said:
... I don't know if that makes perfect sense, but it is all I can conceive to put enough kinetic energy under the FHM. ...
Ballistic fuel handling machines is one of the most creative, out of the box and enetretaining thoughts on this forum.
However, it may just have been parked at the other end of the building, examine at below pics and from the rails on floor one can note that the machine can traverse the building north south or at least such that it can serve all the reactor in the center.
Furthermore, I presume that you will not want to park the FHM over the SFP , that way you minimize the FHM exposure to radiation from the open pool top, so that it does not slowly get radioactive.
[URL]http://posterous.com/getfile/files.posterous.com/billwarner/gbUyXtvgp1FtEJh42PIxIQmyui6J4AkDQt4VonEvEsdqT4673jaZvS2el9eL/rflg-fl2.jpg[/URL]
[URL]http://posterous.com/getfile/files.posterous.com/billwarner/CCk6zJXe49Enj3Fop4ELpKsth2FfRdpaNRMXPGCueXDaGxArPngCOWgWAsA3/rflg-fl1.jpg[/URL]
  • #2,939
[PLAIN]http://posterous.com/getfile/files.posterous.com/billwarner/CCk6zJXe49Enj3Fop4ELpKsth2FfRdpaNRMXPGCueXDaGxArPngCOWgWAsA3/rflg-fl1.jpg[/QUOTE]
You could be right. At the end of the day, I will never be able to prove or disprove what I have proposed, so it is (or has been), most likely, a gigantic waste of time or effort. Maybe it was just hydrogen exploding upstairs. That's what all the news media say.
So, for now, I will just leave it at that and sit back and listen for a while. I am woefully behind anyhow.
Later.
  • #2,940
Sure, I agree. But a super rapid steam (expansion) explosion would be carrying a lot of debris like concrete...
  • #2,941
You could be wrong ;) looking at unit 1 the only thing remaining of the operating floor are the cranes. I ask my self the question If it was not a park default position.. (as it would raise question as what is going on on unit 3
The crane around the FHM is gone or beyond recognition. mind that on unit 4 there was a huge blast just due to the Fuel in the pool, and tha FHM and crane is almost scratch less..
I think the ballistic FHM does not seems that unconceivable .. the FHM on unit 3 is barely recognizable
  • #2,942
Oh, by the way. A hot water boiler has the water tubes in a circle around the central heating chamber which is lined with fire brick. The explosion would come from the superheated water, most likely at a weak point outside the core. External pipe, door seal etc. The combustion chamber would likely have little to do with the steam plume.
  • #2,943
First post for a new member. Looking at the ruins of unit 3, one thing fascinates me, and I haven't seen anyone else touch upon it. Please forgive me if it has been beaten to death and I've missed it- consider this a preemptive mea culpa.
It seems to me that a lot of discussion has gone into the debris that went straight up, and with good reason- that was downright ugly, and the explosion that propelled all that material was incredibly violent. But to my untrained, layman's eye, there also appears to be a lot of evidence that at some point there were some significant and perhaps somehow focused blast effects directed completely *horizontally* off to the east-southeast. The attached markups show what I mean, with annotations detailing what seems like two possible blast paths/debris trails that happened to intersect the upper edge of the turbine building walls above the roofline. In fact, it appears to me that in the image fuku3_2a.jpg, there is a panel blown in on the turbine hall wall roughly in the path of the northmost area of interest, and one of the ventilation covers has been either forced up or sucked up out of its place as the blast wave and associated debris passed- perhaps at the time of the initial fireball.
The most compelling thing to me is the damage to the turbine hall walls: the decorative caps are gone in these hypothetical paths, and the east wall (furthest from the reactor building) has been peeled off right down to the roof line in two places that seem to line up well beyond what I can make myself believe could be ascribed to randomness.
The image fuku3-3a.jpg (low angle looking back to the west) was the one that initially caught my eye, as the localized damage to the east wall in those two places is pretty clear. Which leads me to wonder what sort of phenomenon might have been responsible for this: these two hypothetical paths seem to converge on the northwest corner of the unit 3 reactor building, more or less, which is certainly the most completely demolished. I wonder if this might be evidence of some very energetic event occurring there, perhaps early in the sequence before the bulk of the energy turned upwards. And why over there? I have a hard time imagining what contributed to the apparent angularity. Why did the blast wave not simply propagate out perfectly parallel to the wall of the reactor building?
In any case, the debris pile at the X in the extreme upper right of fuku3_2a.jpg would seem to me to be a good candidate for something that was expelled almost horizontally during this hypothetical event, clipped both sets of walls on the turbine hall on its way by, and finally came to rest across the access road against the smaller building near the water.
I could be, and very probably am, incredibly wrong here. I have no training in this area, and no reason whatsoever to expect that this will prove to be of any value. But I can't help thinking that those two debris paths, taken together with the wall damage, are inconsistent with being deposited vertically from the debris cloud created by the larger, vertically oriented explosion...
  • #2,944
skodises2 said:
First post for a new member. ...
Nice first post! You bring up some interesting observations. I hadn't even noticed those debris patterns until you brought them up. Hmmm...more to think about.
  • #2,945
Hi
Actually it was one of the first thing that was discussed on the thread when, the hole in the turbine building : could it be the concrete slag of the reactor.. at the time we had really low resolution picture.
Since then we got ok picture and you are right we can pretty much think that all those marks (dont let the perspective deceive you) came from the "windows" of last 2 floors( not sure witch floor) .. windows made of concrete panel.. when the building blowup they were eject in strait horizontal line + parabolic @ gravity
I made an other picture on this https://www.physicsforums.com/showpost.php?p=3223071&postcount=2347
if you look at the original HD picture that I used you'll get a better idea
PS: any how nice observation skodises2, keep them coming !
  • #2,946
Jorge Stolfi said:
Here is a labeled version of my "hallucination". The http://www.spiegel.de/images/image-198534-galleryV9-orwt.jpg" , was posted by AntonL.
1 - fuel rods from one assembly?
2 - wider water tube from center of assembly?
3 - bottom of assembly?
4 - racks from spent-fuel pool?
5 - sleeve of assembly?
6 - sleeve of assembly, burst open, oxidized on outer side?
7 - water in/out pipes from spen-fuel pool?
Item 7 seems to match a model of the SPF shown on NHK. Items 6 of course are more likely to be metal roof panels (but where from?)
OK, time to go to bed...
#7 is ventilation ducting,
#6 may be corrugated steel siding
#5 ?
#4 is part of handrrail extwning to left arounf fuel pool,
#3 ?
#2, #1 Compare diameters with the handrails on the refuel maxhine. Handrails are tyoically about 1.25 inch diameter. Water rods are not found on 8x8 fuel. If it is a fuel rod on 8x8 it is about 0.6 inches diameter. A 10x10 rod is only atout .4 inch diameter. A better guess would be conduit or scaffold piping.
I have been corrected on the number of spacers on fuel bundles. There are 7 or 8 spacers so the maximum LIKELY piece of a fuel or mater rod should be on the order of 20 inches. It is incredible that a large number of full length rods would survive an explosiion which "peels open" a fuel channel.
I have known a couple of photo recon interpreters who told me it is hard not to see things after looking at a photo too long or too hard. I have spent a lot of time in BWR reactorbuildings and I don't recognize very much in the wreckage. We've already heard that there was a body in one photo. Next thing is likely to be somebody spotting bin Laden.
  • #2,947
Is there any doubt at this point, that the pools are full of debris? And damage to the spent fuel rods is certain?
  • #2,948
|Fred said:
Hi
Sorry, relplied to wrong post.
  • #2,949
#5 ?
#3 ?
Has the strange shiny grey translucent stuff been discussed yet? I can't see how it can be smoke as it's definitely got a reflective property to it.
  • #2,950
skodises2 said:
It seems to me that a lot of discussion has gone into the debris that went straight up [...] But to my untrained, layman's eye, there also appears to be a lot of evidence that at some point there were some significant and perhaps somehow focused blast effects directed completely *horizontally* off to the east-southeast.
My reading is that the blast was mostly horizontal. The H2 explosion should push in all directions, but presumably the massive crane and the heavy roof structure anchored on the concrete columns presented more resistance than the thin concrete shell on the walls. To me, the dust and debris in the impressive "mushroom" cloud were mostly carried by the buoyant hot steam (gaseous H2O has half the density of O2,N2) a few seconds after the explosion proper. Howere some debris were thrown up before the mushroom started rising, and then fell through it.
49K
449K
273K
16K
11K
